Facelift Jb4 dyno results
gussyldr
West London
Hey peeps just wanted to share my jb4 results
Mods
TT inlet pipe
R600 intake
Gfb Dv+
Turbo back milltek exhaust
My engine light came on and put my car into limp mode after fitting my downpipe so if anyone’s planning on fitting one without a remap I’d recommend 42 draft spacer before fitting which I found out the hard way oh well I’m happy with my results
2E275285 4B2A 41D7 A113 52B95FCF9AE8
Now we just need your JB4 map settings :hi: Great numbers tho!
Reactions: gussyldr
Oh was on map 2 need to to do some logs then give George a shout to tweek map 6 then put back on the dyno but I don’t think I’ll get any more power
Great :racer: you mentioned you had some trouble with your downpipe but you did the run with the downpipe since it's a turbo back system, right? Aaaand what fuel? Think that's about all the questions I could come up with :icon thumright:
Reactions: gussyldr
If you have a JB4 you don’t need a spacer on the downpipe. You can change the FUD to 90 in the settings and this will auto clear the engine management light. (Although some experience issues with cruise control after enabling this feature)
On map 6 you might be able to make some more top end power but you can manage to make much more torque down lower.
Yep did the runs with the downpipe/ full exhaust and i only use shell v power
Ask away
FUD 90 didn’t work for me for some reason so George suggested I use a spacer also once I set up map 6 I’ll dyno again hopefully i can make a bit more:rock:
