If it is the TIP you want. Shipment to Sweden $50US. Price total w shipment, tax and other governmental theft: appr. 250 Euro.
Important to pick correct one with 5 connections to other hoses. "B6.5 A4 (03-05)" was the one I bought and it was correct. The older has only 4.
The thin hose to the pipe beside the airbox, I used the old one when this on the TIP had too small diam. I used rubber vulcanizing tape to make the pipe on TIP thicker to fit OEM hose.
I also bought some extra clamps in stainless steel so I used better size and not too big with long sharp stick out. N75 hoses and airbox removal need some small ones. The 90 degree small hose connecting the pipe from upper crankcase ventilation to the TIP got new clamps in both ends to adjust it perfect with the TIP.
I used extra of these clamps:
Mini clamps, set of 4
8-10 mm
11-13 mm
14-16 mm
Normal hose clamps, set of 2
22-29 mm (2x 2)
13-16 mm (2x2)
The clamps I got left over shipped with the TIP will most likely be used in the future when they all are of good quality.
It was easier to fit the TIP with the hose on the tip to fit the turbo inlet.
A piece of not used plastic sticking out 3-4 cm beside the electric engine cooling fan was an obstacle for the fitment of the TIP. I snapped it off when I could not see any use for it.
