mattyb6
After a breakdown last week And some research and finally a compression test today it's official
Low compression on all cylinders
Results:
Dry. Wet
1. 45psi 96psi
2. 95psi 250psi
3. 50 psi 150psi
4. 120 psi 175psi
To be fair I did put a little bit too much oil into cylinder 2 for the wey test.
But the results still speak for them selves.
so what's next?
The car may be sold to my brother who might fix it
Will the best thing to do is pull the head off and check inspect the head and piston rings?
Then decide from there weather it's rebuild , replace or whatever ?
Results:
Dry. Wet
1. 45psi 96psi
2. 95psi 250psi
3. 50 psi 150psi
4. 120 psi 175psi
so what's next?
