wot do i need?? heated seats
dalejones Jan 25, 2013
  1. dalejones
    dalejones Member
    41
    I bought a 2004 s3 replica with s3 leather seats but the seats are not connected, need to know what i need to do to get the heated seats to work??
  2. NHN
    29,390
    1,733
    Is the climate control a heated seat version, has it got the roller dials from 0-6 for the heated seats part?
  3. chris.vincent3
    chris.vincent3 Own a BMW now, HOWEVER I still own VCDS! VCDS Map User
    604
    34
    You need a climate control unit with the heated switches and also the loom. Its plug and play as far as ive been told. Im yet to do it, need to source the right control unit as i bought the wrong one.. Theres a size difference between double din and single din control units, i need to source a double din one, so ive got a single din spare if its any good to you?
  4. dalejones
    dalejones Member
    41
    Thats the center console, will i be able to have heated seats?
  5. MartayMcFly
    MartayMcFly Booooooost VCDS Map User Gold Supporter
    2,763
    354
    As both the guys said above, you need the heater control on the climate unit. If you get that, and the loom to connect the seats to the controls, then you should be able to.
    One of these, see the rollers and seat graphics at the bottom?
  6. audicruiser
    audicruiser Audi Heaven
    1,865
    Looking at the white patches on the climate button the OP could do with a new climate unit anyway!
    MartayMcFly likes this.
  7. Cookie013
    Cookie013 Member
    This may sound stupid but are all leather seats hated but some arent set up? Ie with the controle unit and loom?
  8. chris.vincent3
    604
    34
    No, if your car didn't come out the factory with heated seats then you dont have the elements in the seats nor the loom.
    You have to source the heated seats, loom and control unit (correct one for your vehicle)
  9. dalejones
    dalejones Member
    41
  10. chris.vincent3
    604
    34
  11. dalejones
    dalejones Member
    41
    May sound dull but how do i find out?
  12. dalejones
    dalejones Member
    41
    The pic of my center console is at the top, can u tell from that?
  13. chris.vincent3
    604
    34
    Of course.. DOH! Sorry, its late for me. You've got a double DIN, so you need one that fits in a double DIN centre console, as they are slightly smaller. As i found out the hard way.. So when you try sourcing one double check from the seller its the double DIN one, way to tell is the sides are flush on a double DIN, and on a single DIN they aren't as the sides come out a bit further.
    Hope that helps.
  14. dalejones
    dalejones Member
    41
    Brilliant thanks mate, now i jst got to make sure my seats are actually heated seats, did u see my ebay link? Can u tell if that is the right double din one i need or will i hav to ask the seller?
  15. chris.vincent3
    604
    34
    If they're heated seats then you will have a plug on both front seats not being used. I did yes, can't tell by the photo I'm afraid and doesn't say in the listing either, so you'll have to ask the seller, or check with someone on here that is a guru at part numbers, they will also be able to tell you the part number of the control unit you will need.
  16. dalejones
    dalejones Member
    41
    Amazin stuff! Thanks for your help! Any ideas wherr i can source the loom part?
  17. audicruiser
    1,865
    kufatec would be where I'd look...
