whirring noise over 60mph sounds like rear end, any ideas?
hank3944 May 14, 2011
  1. hank3944
    hank3944 Member
    146
    Any ideas what this could be guys?
    I am thinking the following:
    Wheel bearings
    4 wheel allignment
    Dodgy tyres
    What order would you guys suggest and in what order according to price?
    Thanks.
  2. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    I would be checking the Bearings....or haldex oil?
  3. The Doctor
    The Doctor Well-Known Member
    1,394
    189
    Whirring or whining? Could be rear transmission on its way out?
  4. voorhees
    voorhees Moderator Staff Member Moderator DSG
    16,144
    1,978
    When was the car last tracked ? Any spacers ? Have you checked that the studs are all tight
  5. [Dave B]
    [Dave B] Daddy
    2,027
    145
    Try switching the rear tyres for the fronts to see if the noise moves. I've had a dodgey tyre make that noise on my s3. If the noise doesn't move it could be a bearing...
  6. hank3944
    hank3944 Member
    146
    Is there a way of actually checking the bearings without changing them?
  7. hank3944
    hank3944 Member
    146
    not sure when the tracking was done (any ideas how much?) dont think there are any spacers (original wheels) will check the studs later.
  8. hank3944
    hank3944 Member
    146
    I really hope not, cars only done 52k surely not.:huh:
  9. The Doctor
    1,394
    189
    Not at that mileage.
  10. voorhees
    16,144
    1,978
    best part of a hundred quid for 4-wheel aligning
  11. hank3944
    hank3944 Member
    146
    Thanks mate
  12. quattro1
    quattro1 Member
    639
    hmm, any ideas how much to get a rear wheel bearing done? sorry to hijack your thread, just im having exactly the same thing and im pretty sure its the bearing
    to check if its totally gone, jack the rear up and give the wheel in question a proper good wiggle, if theres any noticable ammount of movement, bearings gone.
  13. [Dave B]
    [Dave B] Daddy
    2,027
    145
    I paid ~£50 for a rear bearing to be done, only to find out afterwards that it didn't cure it because it was a dodgy tyre. As I mentioned try switching tyres before paying to have the bearing changed. I could of sworn my dodgy tyre was a bearing failure but it wasn't.
  14. Broken Byzan
    13,237
    465
    Is it a new thing or have you just bought the car that's making the noise?
  15. hank3944
    hank3944 Member
    146
    Will do mate. cheers.
  16. hank3944
    hank3944 Member
    146
    The latter. So im kinda problem solving.....
  17. Broken Byzan
    13,237
    465
    That will be the CATD one that was on Ebay then?
    If it was a cheap and easy fix, Ie bearing/alignment the PO would have done it. I recon its the diff at least
