What's missing
Den13 Jan 28, 2013
  1. Den13
    Den13 Member
    240
    [​IMG][​IMG]
    Should these two pipes be joined
  2. Gizmo20VT
    Gizmo20VT Active Member
    294
    By the looks of the pic, that would be for the breather system, that vents excess emissions back into your intake. They are known to break cause of the oil that weakens then plastic/rubber.
    I could be completely wrong thou.
  3. <tuffty/>
    21,869
    4,198
    Yes... its part of the PCV system... I suspect this will also be giving you an air leak and allowing unmetered air in... get it fixed :)
  4. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    ^^ x2 ^^ may be better waiting while the fog clears and take them again.....;)
  5. Prawn
    11,663
    3,661
    A turbo :laugh:
    In all seriousness though, I don't think anything is missing, I think the hard plastic pipe in the lower section has broken off inside the flexible hose, hence them seperating.
    Replace the plastic bit :)
  6. Den13
    Den13 Member
    240
    Oi!!!!!!!!! Dave!!!!!!!!!! Leave my iPhone alone lol ok want to order the part ebay jobby what am I looking for I has been like this from I got the car,just changed the oil and filter ...prity dirty and used and engine flush......a lot of people don't recommend these because they recon they can cause leaks.......rubbish although when I put the new oil in there was a large amount found its way to the floor, think...hope I just misses the hole tho lol
  7. Den13
    Den13 Member
    240
    Turbos are for gays lol
  8. <tuffty/>
    21,869
    4,198
    Considering that the majority of the cars in the 8L section have turbos thats quite a bold statement :)
    Birdy and ShaunS3 like this.
  9. Den13
    Den13 Member
    240
    Lol really.........It was a joke :yahoo:
  10. s3dave
    10,110
    736
    Yeah just get a new part/connector and you will be fine mate..
  11. Den13
    Den13 Member
    240
    Any idea what it's called?
  12. <tuffty/>
    21,869
    4,198
    Its a PCV pipe and the part number should be on it...
  13. Den13
    Den13 Member
    240
    On the pipe or on the missing bit lol
  14. Prawn
    11,663
    3,661
    there is no part missing Den, read my post above. the broken end will be inside the hose.
    Part number will be on the main body, so the lower section.
  15. Den13
    Den13 Member
    240
    Not convinced prawn on the Haynes manual the bit that's missing looks to be quite bulky
  16. Den13
    Den13 Member
    240
    Mine could be different tho also can't find the replacement part anywhere :(
  17. <tuffty/>
    21,869
    4,198
    The part will be available from an Audi dealer...
  18. Den13
    Den13 Member
    240
    Ok will look for the part number later also the evaporative emission charcoal canister ticks,.... Is a faulty
  19. vrbob
    vrbob Thats no Moon, Thats a space station!
    2,375
    171
    They all tick so its not faulty
  20. Den13
    Den13 Member
    240
    Tick loudly and quite often?
  21. <tuffty/>
    21,869
    4,198
    Yes
  22. Den13
    Den13 Member
    240
    Ok why do they do that?
  23. Den13
    Den13 Member
    240
    Also this missing peace will it cause engine management light to come on
  24. <tuffty/>
    21,869
    4,198
    Potentially as it could be allowing un metered air (as I mentioned before) into the engine so the ecu could be compensating for fuel...
    Never logged a 1.6 before so I don't know how intelligent the ECU's are on those...
