It lives again......
Most of the work is done now,and there will be some before and after pics once it's all up and running.
Boost controller programming and wastegate opening need to be checked out,as there's no point in having a wastegate that never opens.
Manifold is fitted,after a bit of machining to get the fuel rail brackets to fit......I'm pretty sure that every job I've given AMD has turned out not to be a simple "fit and forget",as they've so often been billed.
The ATP turbo kit wasn't simple or easy,the LP auxiliary fuel pump upgrade skinned a few fingers,the wider rims were a pain,along with the adjustable topmounts,so it was silly to expect that the manifold would simply pitch up and bolt right on.
Anyhow,in a few days it should be ready for a bit of set-up time.
