syvo's progress thread
Syvo Jan 12, 2012
  1. Westy
    Westy Well-Known Member
    17,440
    1,096
    Yes you do ;)
  2. Reesy
    Reesy Well-Known Member VCDS Map User
    3,639
    148
    Syvo, just buy my downpipe and be done with it.
  3. Syvo
    Syvo IF IN DOUBT GO FLAT OUT
    1,338
    22
    small up-date.
    bought reesy's downpipe after twisting my arm into buying it lol.
    also cheers westy and just for you we have some pics.
    recent purchases:
    new oil catch can as the old one was temporary although lasted alot longer than it should have.
    new drivers side headlight to match the passenger one that i got due to mot failed in august as the crack in it had got alot bigger
    new heater blower as mine is on its last legs sounding like ive got a helicopter in the dash when turn the blowers on.
    air filter heat shield small crease but will panel hammer that flat when fitting it, also will attach oil catch can to this also.
    silicone pipe for the catch can has also been ordered oil/fuel hose to ensure the pipe lasts.
    some 10mm vacum pipe for the pipe going to the inlet manifold to help tidy the engine bay up.
    inlet manifold and rocker cover will be getting sprayed next month. got paint just need to pick up gaskets from work and get the parts preped for my bro to spray.
    car has been for wheel alignment today and some lowering hehe.
    probs been dropped around 10 - 15mm more all round back coilovers all the way down now the fronts have about 8 - 10 threads left
    staying on the stretched 215 tyres reason for extra lowering today.
    geo readout:
    top was before and bottom after.
    camber has been set to 1 degree and 40 mins on the rear. the toe is still in the red but was miles out on the passenger side before fitting the new rear trailing arm thanks to stacys3 on here for supplying the part. the toe was before this readout on 1degree and 10mins on the passenger side its now reading a nice 34mins which i can live with.
  4. Syvo
    1,338
    22
    only few more parts to buy:
    sill covers
    r32 anti roll bar and bushes
    then its off to pipe werx for downpipe and de-cat fitting once this is done make a nice trip to r-tech for stage 2 map
    and finally just got the paint left to sort out both sides and the both bumpers.
    not happy with the passenger side which has been sprayed by penketh auto body's so going back to see him again on Saturday see if he is going to repair his poor workmanship if not off to find another sprayer, would give to me brother but doesn't have a booth to do the work in.
  5. Syvo
    1,338
    22
    my bad ppl dave has just pointed out the crease is ment to be there in the heat shield so will leave that alone lol
  6. Snash7
    Snash7 Member
    84
    Great thread great car man really looks s**t hot.
    Were did you get the heatshield from and is it for a 70mm maf or an s3 80mm
    Grant
  7. Syvo
    1,338
    22
    cheers m8 i got it from s3dave on here he sells them on ebay, its a 70mm maf holed one he also sell s3 maf sized heatshields
  8. Syvo
    1,338
    22
    few more parts turned up today thank's to reesy.
    needs cleaning up and ready for fitting in January.
  9. Dani_B19
    8,962
    317
    I hope he gave you a warranty on them mate haha.
  10. Syvo
    1,338
    22
    lol no warranty but im sure it shall be fine also saves me a load from getting a new one built
  11. Dan-Jnr
    Dan-Jnr Well-Known Member
    1,232
    377
    Should clean up nicely.
  12. Syvo
    1,338
    22
    will post pics once clean
  13. Syvo
    1,338
    22
    well to-day was an eventful day. got the new headlight fitted, horns, thermostat, oil catch can, air filter heat shield, fixed the annoying rattle in the drivers wing, got the passenger head light to fit better.
    thermostat was a nightmare to do, tested it in boiling water first to make sure it worked, then fitted it after a lot of swearing at the bottom bolt, 2 fags l8er the bolt was out. changed the thermostat filled the coolent up with G13 which its changed to now must have got sick of all the + on G12. started the car looked underneath and it was leaking so engine off thermostat out again checked seal and refitted and all fine must have moved the seal first time. 20 mins job turned into hour and half lol.
    the drivers wing was rattling as previous owner thought it would not need bolts in the inside part of the wing "amateurs" found some spare bolts and fitted them and no more rattle.
    fitted new headlight at last been sat in a box for ages now, all good just need to level the beams on both sides done it best i can for now.
    just got the heater blower to fit tomorrow seems simple job to do. and give the car a good clean it was yellow its now yellow with black patches all over it form working on the car and been raining for past two weeks so couldn't wash it.
    finished at working on the car at 4 so decided to rebuild me skates while was board at home parts arrived Monday.
    no pics of the car as was raining again while doing the work. but did get pic of skates just for westy lol.
    from this:
    to this:
  14. Syvo
    1,338
    22
    well finally got round to sorting out the heater blower today was simple job to do, 4 t25 bolts in passenger side behind plastic cover, 1 t25 bolt under glove box and 3 more inside the glove box and presto glove box out 2 7mm bolts holding heater blower in and also a plastic nut underneath cover and the heater blower falls out. had spare unit ready took old blower out to find this inside it.
    so plugged old unit back in tried it and the noise is no more was this bit of foam stuck in the blower causing the problem so will have to send the new unit back as wont need it £40 saved today lol.
  15. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    I thought for a sec your seat was ripped and you found a laptop inside....;)
    bigray likes this.
  16. Syvo
    1,338
    22
    lmao i wish
  17. Syvo
    1,338
    22
    Hi all not been on hear for some time now. Had a muppit crash into the front wing off me car and now the insurance dispute is still going on and carnt afford to insure the car at the moment was looking at selling it this summer but will be breaking the car instead I will upload some pics 2moz of the damage as u can see through out the thread the parts that will be forsale.
    I will be creating a thread in the selling section with a full list of parts for sale
    The car will be off the road as off next Thursday so I will start stripping it down from then as and when ppl need parts
  18. Westy
    17,440
    1,096
    Hi bud, long time. What will you replace it with?
  19. Syvo
    1,338
    22
    It has been m8 probs gonna get a fiesta 1.6tdci as need something cheap to insure until the claim is sorted and good on fuel the car was finally finished got the stage 2 map on it yours brake pads are still going strong m8 on the car.
    Would sell as a whole but doubt it would sell well it's been wrote off twice before and needs a new wing and the front two wheels need refurbing. Would let it go for 2k as it is only has 89k on the clock running 233bhp on 16psi off boost
  20. s3dave
    10,110
    736
    Shame mate, the 8l old school are going thick and fast now....:ermm:
    Anyway good luck with your new purchase..:icon_thumright:
  21. Syvo
    1,338
    22
    i know cheers dave, i may get another in a couple of years as a track toy as it was great fun to drive and own
  22. Syvo
    1,338
    22
    looking at a bike also as the fiesta diesel wont give me the same buzz as the audi did, done me cbt got theory on the 18th march and probs do direct access in April or may, been looking at a zx6r for a first bike.
  23. Syvo
    1,338
    22
    Hi all I couldn't get the pics to load so here is a list off some off the stuff that will be for sale
    Fmic
    3" down pipe for a3 Quattro
    2.5" cat back system (pipe werx) will fit s3 and a3 Quattro
    Tip
    Forge 007p DV
    Full leather reactor interior
    Turbo smart boost gauge with air vent pod
    Oil catch can
    Air filter heat shield
    Fk coil overs
    Fk 11mm spacers hub centric
    18" bbs ch wheels 5x100 9j in custom gum metal grey with Michelin pilot sport 3 tyres
    S3 calliper carriers
    A3 calipers
    Brembo max discs 312mm
    Braded front lines
    S3 rear bumper
    Rs4 front bumper
    1.8t engine ary with ko3s turbo and stage 2 custom code map
    Full a3 interior (dashboard clocks door cards) in blue not black
    Forge rear adjustable tie arms
    S3 front wing passenger
    Rest off the parts are a3 bits
  24. limbo118118
    limbo118118 LORD
    490
    52
    What oil catch can is it? Very intrested cheers
  25. Syvo
    1,338
    22
  26. Syvo
    1,338
    22
    it is a universal one it has 17mm ends irrc although i do have the 17-19mm silicone hose to make it fit the standard audi pipes probs looking around £20 for the catch can with the silicone pipes to make it fir the audi system, please bear in mind collection in person only.
