Surely these springs should not look like this??!!
woofdog Aug 5, 2014
  1. woofdog
    woofdog Member
    44
    10
    [​IMG][​IMG]
    Rear and front there, and they're the same on both sides. When I saw the first one I was thinking ok this one has collapsed but then I discover that all of them are like this, so now I'm confused! Handling is spot on and it's not knocking but there is a bearing type moan which I thought was noises tyres at first... It's a 55 plate sportback tdi.
  2. woofdog
    woofdog Member
    44
    10
    Also worth mentioning there are no breaks or fractures in the springs
  3. smurfworth
    smurfworth Well-Known Member Audi S3
    1,954
    548
    Looks like a lowering spring of some sort to me, only way I could explain it.
    You are correct though the standard springs do not look like these do
  4. Staz
    Staz is a retronaut Moderator VCDS Map User
    6,206
    67
    Aftermarket springs don't normally look like that either. Perhaps someone decided to lower the car by compressing the spring like that?
  5. Gazwould
    Gazwould Well-Known Member
    5,681
    2,305
    They're oem because of the paint markings.
  6. woofdog
    woofdog Member
    44
    10
    I thought this also re the markings! It's a weird one tho how they are all the same..
  7. JohnE
    JohnE 2005 A3 Sport 1.6 FSI
    415
    40
    The paint markings on my 55 reg are circular dots, not squares.
  8. Gazwould
    5,681
    2,305
    Different markings and colours for different model axle weights.
  9. D3mon
    D3mon Active Member
    360
    44
  10. scott_159
    scott_159 Member
    107
    the springs have been heated and compressed. shame really as i thought this kind of bodging has been wiped out now.
    sorry pal but you will require a new set of decent quality lowering springs if you want to keep the same ride height
  11. Sprintblu3
    Sprintblu3 Active Member
    233
    25
    Have you had the springs off and look inside maybe theyve welded them together too
  12. woofdog
    woofdog Member
    44
    10
    Scott this is my conclusion also, they couldn't have all collapsed the same way like that. I don't mind swapping out the springs for some eibachs as it's doing nothing for the tyres and tracking with the current set up. I havent had the springs off yet so can't really see if they've been welded... So to swap for a similar ride height I would think about 30mm would keep the sporty look It has currently??. ImageUploadedByTapatalk1407245010.818760.jpg
  13. scott_159
    scott_159 Member
    107
    im 100% sure they have been heated up whilst on the car. i used to see this quite a bit back in the day ive even seen small but fat U clamps used (like a small fat exhaust u clamp) to clamp the springs to lower them really makes you think of the IQ of these people....
    s3_trev likes this.
  14. woofdog
    woofdog Member
    44
    10
    Unbelievable really, I've never heard of this technique till now, what a **** way to lower the car!!
  15. Av4nt
    Av4nt Well-Known Member Team V10 Team Sprint Audi S6 quattro saloon s tronic
    1,511
    387
    Dafuuuq 0_o
  16. foxymk1
    foxymk1 Active Member
    454
    44
    this was a trick back in the 80s 90s , budget lowering
  17. Dan-Jnr
    Dan-Jnr Well-Known Member
    1,234
    386
    At least we haven't come across a coil being cut out to lower the ride height.
  18. woofdog
    woofdog Member
    44
    10
    Not sure if they are right as they don't locate so good with the top mount. Any ideas?
    MartayMcFly likes this.
  19. -Ju-
    -Ju- Well-Known Member VCDS Map User Team Panther Audi S3
    2,416
    516
    There not the back ones are they lol!
  20. antowens
    antowens Car Nut Regional Rep
    845
    275
    Or upside down ?
  21. woofdog
    woofdog Member
    44
    10
    Lol they are as well. (Back on fronts) I always thought long thin on front short fat on back. Not in this case!!! Cheers
    Dan-Jnr and antowens like this.
  22. -Ju-
    2,416
    516
    Lmao:laugh:
  23. woofdog
    woofdog Member
    44
    10
    Yes I am a big douche! Rubbish day yesterday changed over all the springs to the eibachs which was fine after I put them the right way round ;) check out the old ones below!!!!!
    So after all that I get in the car for a test drive and have no power steering :(( [​IMG]
  24. woofdog
    woofdog Member
    44
    10
    And red warning power steering and amber traction control light
  25. -Ju-
    2,416
    516
    There is a power steering reset which goes something like
    Ignition on
    Turn fully left and hold for 30 seconds
    Turn fully right and hold for 30 seconds
    Return to centre
    Ignition off
    Then hold your breath and keep your fingers crossed!
  26. woofdog
    woofdog Member
    44
    10
  27. -Ju-
    2,416
    516
    Yep that's the one
  28. woofdog
    woofdog Member
    44
    10
    Thanks for your help on this bud, unfortunately the power steering rack is goosed :( I was manhandling the hubs when i was replacing the springs and must of been too ruff with the it. It would of only taken a big pot hole to do the same thing but now have to change the unit £££ :(
