So I only have 70bhp...
shaz8389 Oct 8, 2012
  1. shaz8389
    shaz8389 Member
    43
    I think maybe something is wrong. Power basically falls off by 2000rpm so guessing no boost. Car still drives smoothly and doesn't hit limp when I'm driving but did on the rollers. Guessing clogged VNT vanes?
    The car has never really been fast but never guessed it was that slow. Worst case scenario I expect is needing a turbo change, what's the retail on those little dinky turbos for the 1.9TDi?
    AFN engine
    243,000 miles on the clock
    Still returns 60+MPG oddly enough
  2. boost401
    boost401 New Member
    9
    Whp or crank?
  3. shaz8389
    shaz8389 Member
    43
    Crank. I have no doubt it's accurate. The car is quite slow.
  4. Reesy
    Reesy Well-Known Member VCDS Map User
    3,639
    147
    Sorry, but that post made me laugh out loud.
    Speak to ScottB5, his car is also slow and he had vnt issues earlier in the year.
  5. adamss24
    adamss24 Well-Known Member
    4,519
    382
    There could be a few issues with the car if it does drive slow ! For once they have MAF issues if it cannot meet the requested airflow the car get's in limp mode, also the pump case pressure relief valve might be popped which will mean reduced overall power- it drives bad if it's completely split in pieces. Also VNT mechanism or boost control solenoid can give said issues but the ECU needs scanning for codes. No point stabbing in the dark !
  6. shaz8389
    shaz8389 Member
    43
    It has the well known inlet manifold pressure code. I don't know why I haven't bothered fixing the car in all honesty. I just thought they were all slow.
  7. AR-rkon
    AR-rkon Mod back in a "B" Staff Member Moderator Regional Rep Team V6 Team Silver Audi A6 Audi A4 Audi Avant Owner Group
    1,911
    164
    :lmfao::lmfao::lmfao::lmfao::lmfao::lmfao:
  8. aragorn
    17,807
    679
    Theres some fairly simple tests you can do to check the movement on the VNT actuator, so do those first!
