Original Audi number plate LED's that fit the A3 8P - plug & play!
klik Mar 30, 2012
  1. poli84
    poli84 Member
    425
    57
    What MY is your car though?
    09 or 10?
  2. azialex
    azialex Member
    91
    order them yesterday at Newcastle Audi and won't be ready in 2-3weeks time.
  3. S.
    S. Save the manuals Team Ibis TFSI Owners Group Audi S3 quattro Manual
    2,094
    581
    lol, i've ordered mine yesterday, and they are already here. just need to pick them up.
    why so long?
  4. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    I got mine last week. Ordered 1 day and came the next! Great plate lights, no more faffing with led bulbs! :)
  5. azialex
    azialex Member
    91
    no idea why.
  6. S.
    2,094
    581
    ok...picked them up. had some issues with fitting but at the end managed to make them work without errors on DIS. i've noticed that the contacts are little shorter than a3/s3 ones and i had to straighten angled ends of contacts to make them reach to the cars contacts, it took me few times to get them right, also they must be screwed tight otherwise it could show error. after that everything worked well :D
    looks good.
  7. eastern_s3
    eastern_s3 New Member
    25
    Has anyone successfully got these working on an 2009 manufactured 2010 registered (MY10) A3/S3?
  8. PH1L
    PH1L Gievf Buckets
    3,851
    40
    i have the highest ce for 09's in my car and im fitting mine tonight i will let you know how i get on
  9. eastern_s3
    25
    Thanks mate, keen to hear how you got on
  10. NHN
    29,594
    1,782
    Do you, thought yours was a K Phil, not a P?
  11. Rob2k68
    Rob2k68 Well-Known Member VCDS Map User
    7,083
    10,768
    I think as a rule of thumb if the 10th digit on your vin plate is a number they will work, if it is a letter then they will throw up the error. To help find your 10th digit, the 7th and 8th digits are either 8L or 8P.
  12. lala30
    lala30 Member
    35
    10
    led work OK without errors on DIS
    only if coding good
    I have MY12 and work,
    ress 09: Cent. Elect. (J519) Labels: 8P0-907-063.clb
    Part No SW: 8P0 907 063 N HW: 8P0 907 063 N
    Component: BCM PQ35 M 110 0653
    Revision: 00110 AF
  13. Rob2k68
    7,083
    10,768
    Hi, are you saying there is a setting in VCDS that prevents the DIS error ?
    Cheers.
  14. lala30
    lala30 Member
    35
    10
    yes
    if don't put good coding in BCM, have errors in FIS
    you need to coding BCM to car have LED lighting for number plate
  15. Rob2k68
    7,083
    10,768
    Any chance you could elaborate on that, maybe a screenshot ?
    I know this is the case with LED puddle lights but not found a setting for number plate lights.
  16. lala30
    lala30 Member
    35
    10
    you dont have this in VCDS
    because ross tech dont open this bit
    only can to put all byte
  17. lala30
    lala30 Member
    35
    10
    work only from 0651 and newest
    I can make code just need long code from car BCM
  18. a6_chris
    a6_chris Well-Known Member
    1,883
    160
    Confirmed fitted to A4 B7, worked fine but threw the dash error .. Sorted with resistors now all working fine with no error.
  19. eastern_s3
    25
    Darn, checked my VIN and 10th digit is a letter 8P1A :(
  20. 3DTDi
    3DTDi Member
    239
    Plugged straight into my 57 plate 8P2, no errors both work fine, look great too. Make sure they are screwed in nice and tightly
  21. chrisb72
    chrisb72 Active Member Team Panther Audi S3
    237
    72
    Just got mine today in the post from Stoke Audi for my 56 reg Sportback and they even included 2 new screws which I asked for as my original screw heads were badly worn. I had real trouble getting one of them off, but got there in the end. Sadly I have stratched the plastic surrounding trim slightly, however the new lights look great. I had retro LED bulbs before and the Audi bulbs give a slightly purer white glow compared to a slightly bluey white of the retros.
    The new holders clicked into place notrelying at all on the screws compared to my old ones which didn't sit flush.
    I am really pleased and glad I forked out the extra few £££ even though I'd already upgraded from the original yellow bulbs.
    It's hard to get a true colour balance in the photo, but this is pretty close.
  22. a6_chris
    1,883
    160
    You'll be pleased with the 'glow' at night when it gets dark ;)
    Good job
  23. S.
    2,094
    581
    great looking :D
  24. A3SBQ
    A3SBQ A3 SportBack 2TFSI quattro DSG
    475
    74
    Hi all.
    Just installed the new OEM Audi A8 number plate LED's on too my 2009 A3 SportBack.
    No faulty message inn the DIS. Jippii
    Sorry for the dirty car. The car is produced June 2008
    Part no:
    4H0 943 021
    4H0 943 022​
  25. rennie
    rennie Member
    32
    Clearly see the need just to open out the prongs a tad (second photo).
    Being as the led's are for the A5 number plate light, the housing must just be that bit narrower.
  26. Kelvin_S
    Kelvin_S Member
    243
    So the part number is 4H0 943 021 and 4H0 943 022? Do I just call audi and then pick them up?​
  27. a6_chris
    1,883
    160
    Yes, but they might have to be ordered.
  28. azialex
    azialex Member
    91
    finally found the right screwdriver for them screws after three attempts
    done half and they are working great
  29. KhalifaA3
    KhalifaA3 Member
    82
    How do I tell what MY car is? MY10, MY11, etc...
    Its a 61 plate... September 2011 build.
  30. Rob2k68
    7,083
    10,768
    See post #171. A is 10MY, B is 11MY, etc.
  31. lala30
    lala30 Member
    35
    10
  32. A3_Black_Edition
    A3_Black_Edition Member
    417
    19
  33. Kelvin_S
    Kelvin_S Member
    243
    Just tried this no joy :sob: The right one seems to work sometimes. When I start the car, it dies, and I get a warning. Any ideas? 53 plate
  34. a6_chris
    1,883
    160
    make sure the contacts are making a good contact with the contacts in the car
  35. Kelvin_S
    Kelvin_S Member
    243
    How? As soon as I clip them in, I can't adjust anything
  36. rennie
    rennie Member
    32
    Take them out again and turn them upside down on a flat surface and compare the old light against the new led one's.
    Your'e looking at the difference in height of the prongs - just prise them out a bit so they compare against the old.
    About an eighth of an inch should do it.
    Clip them back in again they should now make a proper contact within the housing on the car.
  37. Kelvin_S
    Kelvin_S Member
    243
    kk thanks, will give it a try
  38. Kelvin_S
    Kelvin_S Member
    243
    Same again :( I think they sold me a faulty left light. What can I use to test if it's working?
  39. rennie
    rennie Member
    32
    Take the left one out again and double check the height is correct once more.
    Also check they are seating flush and do click into place.
    You could possibly check the left one in the right hand holder just to see if it does actually work.
  40. lala30
    lala30 Member
    35
    10
    coding and work !!!!!!!!!!!!!!!!!!!!!!!!!!
