Indicator bulbs
robby Feb 24, 2010
  1. robby
    robby Active Member
    575
    68
    Does anyone know how to change the indicator bulbs in the headlights? just bought some silver ones and can't see how to get to the origionals :(
    thanks
  2. mike foster
    3,967
    I believe you have to remove the front half of the wheel arch liner to gain access to the bulb from inside the wheel arch. Basically just loads of screws to undo ( and put back ) !!
  3. Sarah's A3
    Sarah's A3 MODERATOR V6 S3 Hybrid Staff Member Moderator
    5,920
    30
    Hiya, only had my A3 10 days and changed my front indicators after 2 days lol. What I did, was loosen the 2 bolts that hold the headlamps in near the top, some of jiggling of headlamps and pulled them forward a bit and bingo! managed to get the cover off and replace with diadems (look like soap bubbles in the sun). Lots of scratches but well worth the effort! Looks cleaner and better. Also changed the side lights to bright whites while I was at it. Hope this helps and if I can do it........
  4. Lee_R
    Lee_R Active Member
    2,499
    12
    Wow thats the long way round!!!
    Just jack the car up, remove the 4 screws in the wheel arch liner nearest the front bumper. Pull back and you have enough room to put your arm in and change the bulb. 10 mins per side no worries!
  5. robby
    robby Active Member
    575
    68
    Thanks guys, i'll have a go tommorow
    Are there 2 bulbs either side for indicators? sure i saw a strange looking 1 on the inside as well as the standard 1 at the corners?
  6. I'mRonBurgundy?
    I'mRonBurgundy? Lets make that kitten purr...
    554
    What bulbs did you buy?
  7. Sarah's A3
    5,920
    30
    Theres the main beam bulbs, side lights etc but only 1 indicator bulb at the outer corner.
  8. alfiejts
    alfiejts Member
    352
    I've used Phillips Silver Vision in mine. Its a good silver colour. I've also got some Osrams but they're a bluey colour and not as "silver", so they got dumped onto the shelf.
    I did mine by removing the headlight power cable and simply loosening the headlight mounting bolts. That allowed the headlight to move just enough to reach into the wing to change the bulbs without having to fiddle with bumper or wheel arch liner.
    5 mins.....
  9. robby
    robby Active Member
    575
    68
    Some silver ones off ebay - offset pins same as the rear ones (i hope)
  10. robby
    robby Active Member
    575
    68
    Hmm - might have been a reflection? sure it looked different?
  11. One Spoke
    One Spoke Member
    267
    I wondered what the strange bulb was on the inside of my headlights (I have bi-xenons), until I worked out they were the day time running light bulbs lol
  12. alfiejts
    alfiejts Member
    352
    The genuine Phillips Silvervision are well worth the extra couple of quid over the standard eBay cheapies.
    The silver effect when they are off is much better and the bulb is much brighter when its actually on. The silvering on the cheaper bulbs really affects the brightness....
  13. davej_anderson
    davej_anderson Member
    261
    I was able to change the bulbs just by getting my hand into the corner and a few scraped knuckles later, job done.
    I must have really small hands..................
