GT3076R vs EFR 7064
Ivo Nov 13, 2012
  1. Ivo
    Ivo Member
    55
    Which way would be smarter on an S3?
    What would be the difference in power and spool?
    Not many EFR projects until now....
  2. Andrew@A.L.D
    3,879
    617
    It would help if we had more info on your engine and what your plans are for the car
    Why a GT when the GTX is more inline with the EFR
  3. Ivo
    Ivo Member
    55
    I want everyday street car with nice power band. As I know GT3076 has the same characteristics as GTX3071, but the price is lower.
    Engine is standard 1.8T APY remmaped. I will upgrade the rods.
  4. Prawn
    11,535
    3,475
    I'd stick with a ko4 then :laugh:
    In all seriousness, we need more info, how much power do you want, do you plan to upgrade anything else? the turbo's your looking at will need way more than just rods....
  5. <tuffty/>
    21,356
    3,923
    GT3076r isn't the best choice on a 1.8t... you will need cams or a stroker to get the best out of it else you will be looking at surging issues...
    You will also need more than 'rods' on a turbo that size... to get any power from it you will need to let it rev... large port head, large port inlet manifold, valves and valve springs....
    GT3071r on a 1.8t is a perfectly drivable setup... I know I have one....
    To give you an idea of the sorta thing to expect...
    Don't be fooled though as the car is very drivable but of course you have to learn to drive a bit differently
  6. Andrew@A.L.D
    3,879
    617
    As Prawn said ko4 or a GT28
  7. Sevv
    Sevv Pushing the limits..
    1,324
    120
    not to mention the clutch, injectors, fuel pumps, ideally WMI, custom DP, and a turbo manifold, and a FMIC (if you dont have one , trust me not cheap) im in that process :p
  8. Welly
    Welly VX220 SC Driver :)
    10,696
    129
    Agree with the above, a big turbo project is a money pit.
    I'm on number 2.
    Speedy Steve likes this.
  9. Andrew@A.L.D
    3,879
    617
    I would say mine has cost me about £6k+ may be more
  10. Gizmo20VT
    Gizmo20VT Active Member
    294
    Hi
    I would recommend you browse over a few build threads, see what the results are from each users and their turbo spec and decide what you want exactly, then take it from there.
    The current question your asking is the same as "how long is a piece of string?"
  11. Ivo
    Ivo Member
    55
    I am well aware of all other things, like injectors, exhaust system, fuel pump etc.(I already have FMIC). Going big turbo is expensive. Question is which turbo to choose with GT3071/76 on one side and EFR7064 on the other. They should make similar power a little over 400hp without stroker, but I am not sure if the EFR would give better power curve.
  12. Gizmo20VT
    294
    As you compared the pressure graphs of these to turbos in question?
    also your power curve would have a lot to do on the mapping of the car, not just the spec turbo. Spool can be effected by manifold type, EGT temps, AFR mix's etc.
  13. <tuffty/>
    21,356
    3,923
    Not a turbo anyone has used on here tbh so not sure if that info is available....
    Its worth mentioning the spec of the build regardless when asking questions like these else you will get quizzed..
    I assume you have done some research too? some links to the products and compressor maps maybe of some use to give context...
  14. Sam_
    Sam_ Down under
    3,038
    480
    VW vortex might be worth a look...
  15. Andrew@A.L.D
    3,879
    617
    There is about three in build threadNothing running as yet
