First post - new car
vroomtshh Jan 15, 2012
  1. vroomtshh
    vroomtshh Active Member
    362
    49
    Ok so I've done this a bit backwards. I have a nice diesel 'toy' and I've decided to go for a 1.8t Quattro Audi a4 avant as a daily. There will be a few updates required but all in, it's pretty decent as is
    Comes pretty well specced with leathers, xenons, cruise etc. it's already booked in to be mapped, and next weekend, the exhaust tips will be getting cut off and replaced with something a bit more manly looking. Then maybe a few wee oem+ mods
    One small problem, the headlight washers don't work if anyone has any advice
  2. voorhees
    voorhees Moderator Staff Member Moderator Team V8 Audi S5 s tronic
    16,242
    2,066
    Nice looking avant,have you any water under the car by the headlight washers ?
  3. quattrojames
    14,060
    583
    Welcome to the forum, nice looking car :icon_thumright:
  4. jutlis 3.0
    jutlis 3.0 Member
    211
    nice looking car and a good spec straight out of the box as well
  5. vroomtshh
    362
    49
    If I try to use them? Will have a check tomorrow. Should I be able to manually lift them out the bumper?
  6. voorhees
    16,242
    2,066
    Silly Question Alert !!
    What have you done to work them ?
  7. vroomtshh
    362
    49
    Switched on the lights and sprayed the screen for over a second.
    That's what it says in the manual.
    On previous cars, you could fold the bumper flap back by hand. I can't on this. Didn't try too hard, but was just wondering.
  8. voorhees
    16,242
    2,066
    Just checking,any water under the car ?
    I had to change the washer head on mine ( 60 quid ) it's a ****** to pull up,I'd show a pic but my desktops knackered.
    I'd try vagcat to see a detailed pic
  9. leeds_182
    leeds_182 Member
    121
    Looks nice pal.
  10. Stu!!!
    Stu!!! Member
    60
    Nice clean example :)
    Out if curiosity, what's your diesel "toy" ?
  11. vroomtshh
    362
    49
    Copied this from another forum and forgot that no-one hear knows me :lol:
    Its a MK4 Ibiza Cupra Tdi with a GTB2256vk, full rebuild, Firad injectors, full TB exhaust, custom intercooler, and a huge pile of other stuff.
    Runs approx 280bhp, 500lb/ft
    And can still manage 50mpg if you try :icon_thumright:
  12. vroomtshh
    362
    49
    Just double checked and theres no water under the car. My rear washer isn;t working either, but I assume its typical VAG and will have popped off somewhere
  13. saxonblue
    saxonblue Member
    298
    15
    sound silly, but all the fuses are ok arnt they?????
  14. vroomtshh
    362
    49
    I haven't physically checked yet, but the manual says that the headlight washers and screen washers are operated off the same fuse.
  15. saxonblue
    saxonblue Member
    298
    15
    ok. forgot the washer for the windows are ok,, silly me. worth a look tho, you never know
  16. stu_m
    stu_m Well-Known Member VCDS Map User
    1,441
    nice motor
    is it supposed to have headlight washers or has someone put the bumper on but not plumbed the washers in? just a thought :)
  17. quattrojames
    14,060
    583
    It's got xenons so I imagine they would be oem fitment washers.
  18. vroomtshh
    362
    49
    That's what I thought. And it doesn't look like the xenons or bumper have been added on
  19. quattrojames
    14,060
    583
  20. vroomtshh
    362
    49
    Where would I find the data sticker?
  21. quattrojames
    14,060
    583
    In the service book or spare wheel well usually.
  22. Les 51
    Les 51 A pint of Diesel please!
    687
    Nice Car, Have a look under the passenger front wheel arch near the door, if there is water running down there the pipe has popped off. It's a bit of a pig to push back on. there is a little connector between 2 bits of pipe right up inside the wheelarch. This leads to the rear washer. Otherwise the back washer will need washing. To take the cover off just pull gently on the edge off the cover and it will pull off, the the washer jet just pops off the top of the nut. You can then give it a good clean. I can't help on the front washers though sorry.
    Based on it not being the fuse!
