Audi all sorted now I have a faulty vw :-(
adrenalin84 May 20, 2013
  1. adrenalin84
    adrenalin84 Member
    52
    hi there guys just recently bought a VW GOlf Gt Tdi 57' and already inherited some faults
    Been getting strange intermittent problems
    Symptoms :
    Car drives fine for about 30mins-1hr, then the red power steering light flashes intermittently
    if the car is driven for a bit longer the esp light comes on and goes off, longer again the power steering light flashes red/yellow/red/yellow and steering assistance is reduced, i begin to get 3 beeps followed by abs then all other lights on the dash flicker
    As this is happening the car struggles to start and the alarm sounds as soon as you try locking the car.
    dealership scan returned 50+ faults all of no communication - intermittent and low voltage intermittent across many modules
    - all codes can be cleared and disappear until the above symptoms start again.
    I have already replaced the battery and checked 14v across the battery when engine is running.
    anyone had anything similar that could point me in the right direction?
    Rarely happens whilst driving, usually occurs when the engine is restarted during journey, and will not appear atall on shorter journeys.
  2. gen.heinz guderian
    gen.heinz guderian Well-Known Member
    1,346
    126
    How did it run after battery was replaced?
  3. @udi A3
    @udi A3 Site Sponsor Site Sponsor VCDS Map User
    1,820
    197
    Which fault codes come back again after driving?
  4. adrenalin84
    adrenalin84 Member
    52
    Car ran exactly the same after a new battery, fault codes are across all modules as intermittent voltage, weirdly the car drives fine during cool temperatures with no lights but when the temp is higher outside warning lights come on one by one progressively.
  5. adrenalin84
    adrenalin84 Member
    52
    Until I have a full Christmas tree lol
  6. Audi Doodah
    Audi Doodah Active Member
    377
    35
    Check tension on aux belt and condition of all pulleys etc. Could be slipping due to expansion when getting hot. It's common between the power issues (alternator) and reduced steering assistance (PAS pump).
  7. adrenalin84
    adrenalin84 Member
    52
    Would that explain this thought
    Vw golf major electrical problem - YouTube
  8. adrenalin84
    adrenalin84 Member
    52
    Please excuse the music lol
  9. Audi Doodah
    377
    35
    Alternator provides electricity - driven by aux belt. PAS pump provides steering assistance - driven by aux belt. That's the theory of my suggestion. So, you tell me...does the aux belt check out ok? If so, what about:
    Alternator wiring loose/damaged?
    Power supply lines to ecu loose/damaged?
    Water in ecu?
    Dry solder joints in ecu expanding when warm?
    Any of these suggestions could explain the problems you're having or none of them. Just throwing ideas out there, based on the symptoms you describe, to possibly help you trace the issue.
    :thumbsup:
  10. adrenalin84
    adrenalin84 Member
    52
    Any suggestions are truly welcome I will investigate tomorrow, can't even lock the car as the alarm sounds constantly when it is at its worst, cools down all is okay. Only thing that might contradict the belt theory is that it is doing it with just the ognition on and no engine started
  11. Audi Doodah
    377
    35
    Engine was running in your video :laugh:
    Have you checked voltages when it's having it's eppy?
  12. adrenalin84
    adrenalin84 Member
    52
    sorry we have been getting bad weather here....should have done it on saturday......doh!
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: Malfunction 1010
    03-ABS Brakes -- Status: Sporadic communication error 1000
    08-Auto HVAC -- Status: Malfunction 1010
    09-Cent. Elect. -- Status: Malfunction 1010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: Malfunction 1010
    17-Instruments -- Status: Malfunction 0010
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: Malfunction 1010
    44-Steering Assist -- Status: Malfunction 1010
    46-Central Conv. -- Status: Malfunction 1010
    52-Door Elect, Pass. -- Status: Malfunction 1010
    56-Radio -- Status: Malfunction 0010
    Address 01: Engine Labels: 03G-906-016-BKD.lbl
    Part No SW: 03G 906 021 PP HW: 03G 906 021 AN
    Component: R4 2,0L EDC 000SG 1264
    Revision: --H07--- Serial number: VWX7Z0G63N205F
    Coding: 0000072
    Shop #: WSC 01279 785 00200
    VCID: 7CFD85543FF078E
    1 Fault Found:
    005704 - Powertrain Data Bus
    P1648 - 000 - Failure - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 2
    Fault Frequency: 2
    Mileage: 72968 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 21:34:11
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 12.31 V
    Bin. Bits: 00000100
    Bin. Bits: 00000100
    (no units): 0.0
    Readiness: 0 0 0 0 1
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
    Component: ESP FRONT MK60 0101
    Revision: 00H11001
    Coding: 0023170
    VCID: 73EFAE6812AE376
    No fault code found.
    Address 08: Auto HVAC Labels: 1K0-820-047.lbl
    Part No SW: 1K0 820 047 FT HW: 1K0 820 047 FT
    Component: Climatic PQ35 141 0909
    Revision: 00141027 Serial number: 00000000000000
    Shop #: WSC 00000 000 00000
    VCID: 7BFF86483AFE7F6
    3 Faults Found:
    01336 - Data Bus for Comfort System
    014 - Defective - Intermittent
    01299 - Diagnostic Interface for Data Bus (J533)
    004 - No Signal/Communication - Intermittent
    01317 - Control Module in Instrument Cluster (J285)
    Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
    Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
    Component: Bordnetz-SG H54 2202
    Revision: 00H54000 Serial number: 00000007268624
    Coding: E5890F2700041500471400001400000000087F075C00010000 0000000000
    Shop #: WSC 01287 785 00200
    VCID: 71E3A46068B2056
    Subsystem 1 - Part No: 1K2 955 119 E Labels: 1KX-955-119.CLB
    Component: Wischer 250607 021 0501
    Coding: 00038805
    Shop #: WSC 01287
    Subsystem 2 - Part No: 1K0 955 559 R Labels: 1K0-955-559-AF.CLB
    Component: RegenLichtSens 010 1010
    Coding: 00208933
    Shop #: WSC 01287
    9 Faults Found:
    Freeze Frame:
    Fault Status: 00101110
    Fault Priority: 2
    Fault Frequency: 254
    Reset counter: 30
    Mileage: 69412 km
    Time Indication: 0
    Date: 2005.09.13
    Time: 31:63:63
    Freeze Frame:
    OFF
    Voltage: 12.60 V
    OFF
    OFF
    OFF
    OFF
    OFF
    02071 - Local Databus
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 30
    Mileage: 1048575 km
    Time Indication: 0
    Date: 2005.09.13
    Time: 31:63:63
    Freeze Frame:
    OFF
    Voltage: 12.30 V
    OFF
    ON
    OFF
    OFF
    OFF
    00532 - Supply Voltage B+
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 27
    Mileage: 1048575 km
    Time Indication: 0
    Date: 2005.09.13
    Time: 31:63:63
    Freeze Frame:
    OFF
    Voltage: 8.95 V
    OFF
    OFF
    OFF
    OFF
    OFF
    Freeze Frame:
    Fault Priority: 2
    Reset counter: 30
    Mileage: 1048575 km
    Time Indication: 0
    Date: 2005.09.13
    Time: 31:63:63
    Freeze Frame:
    OFF
    Voltage: 12.35 V
    OFF
    ON
    OFF
    OFF
    OFF
    00466 - Control Module for Steering Column Electronics (J527)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 18
    Reset counter: 22
    Mileage: 72111 km
    Time Indication: 0
    Date: 2005.09.13
    Time: 31:63:63
    Freeze Frame:
    OFF
    Voltage: 12.40 V
    OFF
    ON
    OFF
    OFF
    OFF
    01332 - Door Control Module; Passenger Side (J387)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 2
    Mileage: 72559 km
    Time Indication: 0
    Date: 2005.09.13
    Time: 31:63:63
    Freeze Frame:
    OFF
    Voltage: 12.35 V
    OFF
    OFF
    OFF
    OFF
    OFF
    00446 - Function Limitation due to Under-Voltage
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 27
    Mileage: 72807 km
    Time Indication: 0
    Date: 2005.09.13
    Time: 31:63:63
    Freeze Frame:
    OFF
    Voltage: 6.80 V
    OFF
    ON
    OFF
    OFF
    OFF
    00153 - Windshield Wiper Motor; Driver Side (V216)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 30
    Mileage: 1048575 km
    Time Indication: 0
    Date: 2005.09.13
    Time: 31:63:63
    Freeze Frame:
    OFF
    Voltage: 12.30 V
    OFF
    ON
    OFF
    OFF
    OFF
    01598 - Drive Battery Voltage
    000 - - - Intermittent
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 3
    Reset counter: 27
    Mileage: 72653 km
    Time Indication: 0
    Date: 2005.09.13
    Time: 31:63:63
    Freeze Frame:
    ON
    Voltage: 13.95 V
    ON
    ON
    OFF
    OFF
    OFF
    Address 15: Airbags Labels: 1K0-909-605.lbl
    Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
    Component: 38 AIRBAG VW8 020 2300
    Revision: 05020000 Serial number: 0038PD1B3UNV
    Coding: 0013112
    Shop #: WSC 01269 785 00200
    VCID: 3D7B4850646AB16
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 BC HW: 1K0 953 549 BC
    Component: Lenksäulenmodul 036 0070
    Coding: 0000012
    VCID: 74EDAD7417A030E
  13. adrenalin84
    adrenalin84 Member
    52
    1 Fault Found:
    Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
    Part No SW: 1K0 920 964 B HW: 1K0 920 964 B
    Component: KOMBIINSTRUMENT VDD 1212
    Revision: V0002000 Serial number: VWX7Z0G63N205F
    Coding: 0003403
    Shop #: WSC 00657 210 88489
    VCID: 2C5D75148F1028E
    11 Faults Found:
    01314 - Engine Control Module
    Freeze Frame:
    Fault Priority: 2
    Reset counter: 30
    Mileage: 69488 km
    Time Indication: 0
    01316 - ABS Control Module
    Freeze Frame:
    Fault Priority: 2
    Reset counter: 30
    Mileage: 69488 km
    Time Indication: 0
    01321 - Control Module for Airbags (J234)
    Freeze Frame:
    Fault Priority: 2
    Reset counter: 27
    Mileage: 69488 km
    Time Indication: 0
    01309 - Power Steering Control Module (J500)
    Freeze Frame:
    Fault Priority: 2
    Reset counter: 30
    Mileage: 69488 km
    Time Indication: 0
    01330 - Central Control Module for Central Convenience (J393)
    Freeze Frame:
    Fault Priority: 2
    Reset counter: 26
    Mileage: 71374 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 17:04:55
    00457 - Control Module for Network (J519)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 14
    Reset counter: 25
    Mileage: 72170 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 17:07:04
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 2
    Reset counter: 26
    Mileage: 72788 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 16:37:38
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 4
    Reset counter: 27
    Mileage: 72653 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 20:17:35
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 40
    Mileage: 72653 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 20:18:33
    Freeze Frame:
    Fault Priority: 2
    Reset counter: 30
    Mileage: 69488 km
    Time Indication: 0
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 17
    Reset counter: 26
    Mileage: 1048575 km
    Time Indication: 0
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 K HW: 1K0 907 951
    Component: J533__Gateway H04 0021
    Revision: H04 02 Serial number: 210607F1000674
    Coding: 3D0F034007000001
    VCID: 2F676218BE06536
    11 Faults Found:
    Freeze Frame:
    Fault Status: 00110100
    Fault Priority: 2
    Fault Frequency: 31
    Reset counter: 24
    Mileage: 70381 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 18:28:36
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 104
    Reset counter: 29
    Mileage: 69519 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 17:57:07
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 225
    Reset counter: 29
    Mileage: 69499 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 14:26:26
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 2
    Reset counter: 21
    Mileage: 72653 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 15:04:12
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 32
    Reset counter: 24
    Mileage: 71379 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 17:48:02
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 3
    Reset counter: 24
    Mileage: 72596 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 18:11:58
    01331 - Door Control Module; Driver Side (J386)
    Freeze Frame:
    Fault Priority: 2
    Reset counter: 25
    Mileage: 69516 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 16:24:36
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 248
    Reset counter: 25
    Mileage: 71374 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 17:10:27
    Freeze Frame:
    Fault Priority: 2
    Reset counter: 25
    Mileage: 69510 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 15:30:33
    01320 - Control Module for Climatronic (J255)
    Freeze Frame:
    Fault Priority: 2
    Reset counter: 25
    Mileage: 70629 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 13:42:09
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 2
    Reset counter: 25
    Mileage: 72653 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 19:35:29
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Component: IMMO VDD 1212
    Shop #: WSC 00773 210 88422
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
    Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
    Component: Tuer-SG 006 120B
    Coding: 0000564
    VCID: 387559444B4894E
    9 Faults Found:
    01811 - Supply Voltage for Door Controller; Drivers Side (J386)
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K2 909 144 M
    Component: EPS_ZFLS Kl.069 H08 1901
    Shop #: WSC 00000 028 00001
    VCID: 3669577C415C62E
    4 Faults Found:
    01312 - Powertrain Data Bus
    Freeze Frame:
    Mileage: 69920 km
    Temperature: 21.0°C
    Voltage: 14.40 V
    Voltage: 14.20 V
    00625 - Vehicle Speed Signal
    Freeze Frame:
    Mileage: 72410 km
    Temperature: 43.0°C
    Voltage: 12.10 V
    Voltage: 11.90 V
    Freeze Frame:
    Mileage: 72670 km
    Temperature: 7.0°C
    Voltage: 11.40 V
    Voltage: 11.20 V
    Freeze Frame:
    Mileage: 72940 km
    Temperature: 39.0°C
    Voltage: 12.00 V
    Voltage: 11.80 V
    Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
    Part No: 1K0 959 433 AJ
    Component: KSG 0401
    Coding: 01C802087F2D8405485AC69010CC
    VCID: 78F599440BC854E
    Part No: 1K0 951 605 D
    Component: LIN BACKUP HORN H07 9001
    Component: NGS No Answer
    Component: IRUE No Answer
    7 Faults Found:
    00830 - Convertible Top Control Module (J256)
    01517 - Control Module for Trailer/Towing Sensor (J345)
    01135 - Interior Monitoring Sensors
    00323 - Vehicle Inclination Sensor (G384)
    00668 - Supply Voltage Terminal 30
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
    Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
    Coding: 0000564
    VCID: 39735C4070428D6
    9 Faults Found:
    01812 - Supply Voltage for Door Controller; Pass. Side (J387)
    Address 56: Radio Labels: 1K0-035-1xx-56.lbl
    Part No: 1K0 035 186 R
    Component: Radio BVX 020 0032
    Coding: 0040401
    Shop #: WSC 00718 210 84015
    VCID: 356B50705C5A696
    5 Faults Found:
    01305 - Databus for Infotainment
    00856 - Radio Antenna
    011 - Open Circuit
    00849 - S-contact at Ignition/Starter Switch (D)
  14. Audi Doodah
    377
    35
    As nearly every fault is a databus issue it still points to supply voltage, ecu and associated wiring.
    Good luck!
  15. adrenalin84
    adrenalin84 Member
    52
    starting to think i should just send it to auction and hope its a cold day XD
  16. @udi A3
    1,820
    197
    Have you asked Rosstech for advice assuming its a genuine cable? There may be one or two modules throwing errors everywhere else. For instance an abs ecu fault I have read could error elsewhere.thats the longest list ive ever seen though, suggest talking to an auto electrician!
  17. bearthebruce
    bearthebruce Ross-Tech, LLC
    343
    21
    It's not genuine... it is a clone.
    gen.heinz guderian likes this.
  18. @udi A3
    1,820
    197
    How can you tell a clone from the logs?! Hmm maybe that wont get answered on here. A pm would be nice :D
  19. bearthebruce
    343
    21
    You are correct. The question will not be answered.. not in the forum nor by PM. But, suffice it to say, there are means by which we know.
