Help please!
aarronrobson1
Newcastle
Ok so im wanting to buy some new alloys and have seen a couple of sets I like including these off fleee bay, problem is i have no idea about cars lol
will these fit ? they are 20" 5 stud tyre size 235/30/20
pcd is 100 and et35
here is the car they will be going on 2009 audi a4 sline
Many Thanks
Aarron
Not sure if they'll fit or not, but i think it'll make your ride interesting.........
There are two other factors which you need to consider. The first is the bore size of the wheel (centre hole), most early Audis have a bore size of 57.1mm whereas the B8's have a bore size of 66.56mm now. The second is the width of the wheel 8J, 8.5J or 9J. I also think the bolt pattern on the B8 A4 is 5 x 112 and not 100 (PCD). Therefore I dont think the wheels you refer to will fit, but you could try posting on this thread for some help:-
http://www.audizine.com/forum/showthread.php?350903-learning-from-the-b8-a4-wheel-setups
See also this thread:-
http://www.audizine.com/forum/showthread.php?349752-B7-wheels-to-B8&highlight=bore
I think you will also need to give you suspension set up in your posting
Neil
It looks like you have the same wheels as me, so presume you are currently running on 18's. If you are, there is a possibility your car is lowered by 30mm from the standard spec. What I understand from reading other threads is that the car can only be lowered by 20mm if you want to run on anything bigger.
yeh mate i have 18"s on at the mo, so ive went for my 2nd choice of wheels set of 19" finich firenze's just need to pick between black or silver lol.
thanks for the replys
Aarron
Like Crazyfool has mentioned check how much your car is lowerded as they may rub. I would go for black
17
969
41
3K
387
