Sometimes my econ on the climate control will turn off by pressing the button but recently it has started to refuse to be turned off. Is there a genuine reason for it to be stuck on or is there a fault somewhere? Cheers
It usually means your due for a regas IIRC....
Might be wrong but there will be someone along to correct me if im wrong ....or im pretty sure they'll be numerous threads about the same issue in the search field!
It generally means there is a fault in the pressure in the system, it's often due to low gas, or maybe a fault in the compressor. Have a look in the Aircon forum, but THIS will start you off.
