I know all about the stickies,i read them years ago and was impressed that Glen went through all that effort to show his findings.
I was impressed until he tells me something i know to work doesnt work because HE has tried it and it did nothing only to then be told how he actually did the test,the clue is in the name "straight intake" not just shoving a piece of pipe on the maf and bunging a filter on the end.
James...please let go of your hard-on you have for your 'straight intake'.
It's only you that rattles on about it...
I only mentioned I'd tried the best version of what was available.
If you actually understood what the intake you are describing did, maybe you'd post less crap.
A reducing diameter intake as you describe - whether it has a big cone on the end or not - does two things:
Speed up the airflow, thus giving a slight rise in pressure.
Gives laminar flow into the compressor vanes.
Am I correct?
So...speeding up the airflow can be achieved by going to a gradually smaller diameter tube, from a larger one.
4" to 3" to TIP...does the same thing.
The slight increase in pressure can be countered by picking the cold air up from the area in the front bumper that has the highest pressure - as measured using a manometer.
The results are the same...or, possibly even more 'ram air' from the set up I had. And it gave no measurable gains....
As for laminar flow, you only need a couple of times the diameter of the inlet to the turbo to get laminar flow...to get it exact you need to do the maths with Reynolds number etc...but experience shows beyond 1.5 x diameter the flow is all but perfectly laminar...which really adds no value to the long straight inlet.
Buy hey, you go on arguing a point that was never part of the original discussion all you like.
