Control module of parking aid lost coded
manueltg89
Spain
Hello, I'm new to the forum, I have a problem that has me desperate, let's see if you can give me a hand. A few days ago the Parking aid stopped working on my A3 8V Limousine Design Edition 1.6 TDI 116 CV de 2018, I put VAGCOM in and it tells me that the control unit is not coded, the code appears: Coding: 0000000000
Code:
Address 10: Park/Steer Assist (J446)       Labels:| 5Q0-919-294.clb
   Part No SW: 5QA 919 294 B    HW: 5QA 919 294
   Component: PDC 8 KanalH07 0044
   Serial number: 000308418018047
   Coding: 0000000000
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_EPHVA18AU3700000 009035
   ROD: EV_EPHVA18AU3700000.rod
   VCID: 4B95D22BE2C519D1E4-801E
3 Faults Found:
13636352 - Control module not coded
          U1013 00 [009] - -
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 0
10487040 - invalid data record
          B2005 00 [009] - -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 0
9153648 - ROD - Unknown Error Code
          - 00 [009]
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 0
I have seen that someone on the forum has published a code for this unit which exactly matches my: Part No SW: 5QA 919 294 B, the code that has been published is: (0471155811) I have tried it and it does not work, I have I have made some modifications since my car does not have an automatic transmission and I have tried several combinations, for example: (0471155841, 0471155801, 04711558C1...), but impossible, all of them tell me that it is out of range.
I have tried listening to all the sensors in the car and they all have sound, so I rule out that it is the sensors themselves.
I don't know if the same thing could have happened to any of you.
Thank you so much.
All the best.
invalid data record = you wont be able to code the control unit until this is resolved. Suggest visiting a specialist with the needed software to flash the correct parameters back to it.
Thank you very much for your prompt response. Is it common for this to happen? I parked the car and it was working correctly, when I started it again after 2 hours the message came up.
Not common at all. This normally happens when 1) someone is trying to retrofit / install a module and uses incorrect software or 2) when a module goes faulty. I think your problem is the latter
Yes, it seems that the module has failed. When I go to the workshop I will put in the diagnosis. Thank you.
