A3 8P Facelift from AFS headlights to non-AFS
arizona98
Warsaw
Hello All,
Car: Audi A3 8P Facelift
I've recently switched my AFS headlights (silver corners) to brand new Hella non-AFS bixenons. The issue is that they're not self-leveling and there's error about AFS on the dashboard. Previously it was not an issue, so I assume that the sensors are all right. Hella headlights should also self-level, but not turn with the wheels.
What can I do to make the error disappear and make them self-level again?
Any help would be grateful!
Wiring is different, levelling module is different & coding has to be changed.
That's the only way to fix it to level properly or fit afs lights again.
Thanks for a reply.
Even if it's not a retrofit?
The only difference is the headlight itself and it's so complicated?
I am facing the same issue as him: YT link
As I've advised, that's the only ways to fix it to work.
Thank you for the reply.
Is there someone that done this? What changes are needed in the wiring, which module should be replaced to which one?
