Holy smokes.. you did a number on that LOL!!
It's snapped the shaft and mullered the compressor wheel. Does look like an over speeding problem for sure .
It has to be a turbo control issue or
Another reason you can get over boosting is due to the fact of a boost leak, what happens in that case is the air compressed by the turbo is lost . The map sensor sees less boost and doesn't control the n75 to turn the turbo down. It actually will ask for more pressure to compensate for what's lost in the leak..
I know the figures aren't right here but use this as an example.
You're making 1 bar of boost in a perfect situation..
Then you have a boost leak which leaves you making .5 bar,
Your ECU thinks the turbo isn't making enough so it closes the vanes to spin the turbo up some more to push it back up to 1 bar,
So the turbo is now making the 1 bar it's asking for but it's working twice as hard to overcome the leak.
Before you know it. Kaboom, she gone.
Sent from my G8141 using Tapatalk
