Bulb error on ignition on
Matt268uk
A3 Sportback
Christchurch, Dorset
Hi all
I've been asked to scan a car for someone that has a bulb error on ignition on. From what i've been told the car is a 2010 with a 2013 facelift front, he has had no errors since owning the car but recently had to have audi reinstall some software with Odis. Since having this done the car has been throwing the bulb error even though there is no signs of any when turning the lights on.
Can anyone check the scan and point me in the right direction to try and resolve this for him.
Many thanks. Matt.
VIN: WAUZZZ8F6AN015808 License Plate: SIMON
Mileage: 145250km-90254mi Repair Order:
Chassis Type: 8F-AU48 (8T0)
Scan: 01 02 03 05 06 08 09 10 14 15 16 17 19 1B 22 26 30 36 42 46
47 52 53 55 56 5F 62 72
VIN: WAUZZZ8F6AN015808 Mileage: 145250km-90254miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
14-Susp. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1B-Active Steering -- Status: OK 0000
22-AWD -- Status: OK 0000
26-Auto Roof -- Status: OK 0000
30-Special Function II -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CAKA) Labels:| 06E-907-551-CAK.clb
Part No SW: 8K0 907 551 HW: 8K0 907 551
Component: 3.0T SIMOS84 H06 0005
Revision: --------
Coding: 011C000C240F0128
Shop #: WSC 02145 785 00200
ASAM Dataset: EV_ECM30TFS8K0907551 A01007
ROD: EV_ECM30TFS8K0907551_A01.rod
VCID: 6ED46934B157A13A3F-803A
No fault code found.
Readiness: 0110 1001
Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
Part No SW: 8K1 927 156 B HW: 0B5 927 156 E
Component: 0B5 30TFSIRdW H03 0002
Revision: --H03--- Serial number: 0000001158
Coding: 000001
ASAM Dataset: EV_TCMDL501 A02044
ROD: EV_TCMDL501.rod
VCID: 3460BB5C9FFBCBEA09-8060
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 CA HW: 8K0 907 379 CA
Component: ESP8 quattro H04 0010
Revision: -------- Serial number: --------------
Coding: 292D0A
Shop #: WSC 02391 823 56573
VCID: 7AFC5564F51FFD9A93-802E
Address 05: Acc/Start Auth. Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 DQ HW: 8K0 907 064 DQ
Component: BCM2 1.1 H02 0326
Coding: 05130F
Shop #: WSC 02399 823 56573
VCID: 020C2D849DCFB55ACB-8056
Subsystem 1 - Part No: 8K0 905 852 D
Component: J764 ELV MLB
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 06: Seat Mem. Pass (J521) Labels:. 8T0-959-760.clb
Part No SW: 8T0 959 760 C HW: 8T0 959 760 C
Component: MEM-BFS H10 0074
Revision: AA000000 Serial number: 00001010040158
Coding: 00217025002C00000000
VCID: 4382E880C2557C5280-8016
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T2 820 043 AF HW: 8T2 820 043 AF
Component: KLIMA 3 ZONEN H08 0171
Revision: D0000000 Serial number: 01271120091919
Coding: 66170000
VCID: 76E44154C10799FAF7-8022
Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb
Part No SW: 8K0 907 063 N HW: 8K0 907 063 N
Component: BCM1 1.0 H25 0392
Revision: 09025001 Serial number: 00000000530088
Coding: 260050914034AF313F09000000005D5D0F9DC3CA02010141000000
Shop #: WSC 51386 002 104857
VCID: 3A7C9564B59F3D9AD3-806E
Subsystem 1 - Part No SW: 8F2 955 119 HW: 8K2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 261109 H05 0021
Serial number: SWF09110265022
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 10705678
Coding: 02562A
Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
Component: E1 - LDS H08 0090
Serial number: 00000000000812090327
2 Faults Found:
02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 226
Mileage: 145259 km
Time Indication: 0
Date: 2019.01.27
Time: 10:21:00
02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 226
Mileage: 145259 km
Time Indication: 0
Date: 2019.01.27
Time: 10:21:00
Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb
Part No SW: 8K0 919 475 J HW: 8K0 919 475 A
Component: PARKHILFE 8K H06 0050
Revision: 11001001 Serial number: 39840934403021
Coding: 100102
VCID: 4088E78CD343674A9D-8014
Address 14: Susp. Elect. (J250) Labels: None
Part No SW: 8R0 907 364 B HW: 8K0 907 364
Component: DAEMPFUNGS-SG H09 0053
Revision: 00000000 Serial number: 13110906140002
Coding: 050181
VCID: 397E8A68B0993682DA-806C
Address 15: Airbags (J234) Labels:* 8F0-959-655.clb
Part No SW: 8F0 959 655 HW: 8F0 959 655
Component: AirbagVW-AU10 H10 0430
Serial number: 003A4D062Y4X
Coding: 30363635353130303030554A305238463053
Shop #: WSC 02135 785 00200
ASAM Dataset: EV_AirbaAU10SMEAU485 001004
ROD: EV_AirbaAU10SMEAU485.rod
VCID: 75E64658D40192E2FE-8020
Crash sensor for side airbag: driver side:
Serial number: 6334MSME4E34382DO
Crash sensor for side airbag: front passenger side:
Serial number: 6344MSME4D741455H
Crash sensor for side airbag: rear: driver side:
Serial number: 6352QSME54460D20B
Crash sensor for side airbag: rear: passenger side:
Serial number: 6362QSME5446092EM
Crash sensor for front airbag: driver side:
Serial number: 63732SME71192374X
Crash sensor for front airbag: front passenger side:
Serial number: 63832SME4A200866-
Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb
Part No SW: 8K0 953 568 G HW: 8K0 953 568 G
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90319IL3000FO
Coding: 000036
VCID: 3E749974A9B711BAEF-806A
Component: E221 - MFL H02 0003
Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb
Part No SW: 8T0 920 981 M HW: 8T0 920 981 M
Component: KOMBIINSTR. H34 0255
Revision: 00000000 Serial number: CI435C9C9
Coding: 2F071900B3002600010000
VCID: 4684F194F167497AA7-8012
Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb
Part No SW: 8T0 907 468 T HW: 8T0 907 468 K
Component: GW-BEM 4CAN-M H09 0105
Revision: EB800053 Serial number: 5300E09C0303F3
Coding: 00C303
VCID: 52ACDDC40D2FE5DA3B-8006
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H06 0170
Serial number: 1909ECF4301109
1 Fault Found:
03041 - Energy Management Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 226
Mileage: 145259 km
Time Indication: 0
Date: 2019.01.27
Time: 10:09:07
Freeze Frame:
Bin. Bits: 10111
Voltage: 11.60 V
Count: 6
Address 1B: Active Steering (J792) Labels: None
Part No SW: 8K0 907 144 E HW: 8K0 907 144 E
Component: DYNAMIKLENK. H06 0580
Revision: 50001005 Serial number: --------------
Coding: 840000
Shop #: WSC 51386 002 1048576
VCID: 316EB24868E9FEC262-8064
Address 22: AWD (J492) Labels: 8K0-907-163.clb
Part No SW: 8K0 907 163 HW: 8K0 907 163
Component: 4 Wheel Drive H09 0004
Serial number: 001311090001036
ASAM Dataset: EV_AllWheelDiffeQSPCAN 003007
ROD: EV_AllWheelDiffeQSPCAN.rod
VCID: 6DD66E38BC515A2206-8038
Address 26: Auto Roof (J256) Labels:* 8F0-959-255.clb
Part No SW: 8F0 959 255 HW: 8F0 959 255
Component: VSG-AUDI-B8 H09 0170
Coding: 010000
ASAM Dataset: EV_ElectRoofContr 001007
ROD: EV_ElectRoofContr.rod
VCID: 71EE7248A069BEC222-8024
Address 30: Special Function II (J843) Labels: 8K0-907-440.clb
Part No SW: 8K0 907 440 B HW: 8K0 907 440
Component: STS H04 0010
Revision: S0H04000 Serial number: 00000000010705
Coding: 01010101000000000000000102
Shop #: WSC 02391 823 56541
VCID: 2D56AE3874D19A2246-8078
Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb
Component: MEM-FS H10 0074
Revision: AA000000 Serial number: 00001010040067
Coding: 00397B25002C00000000
Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb
Part No SW: 8K0 959 793 H HW: 8K0 959 793 D
Component: TSG FA H11 0306
Revision: Serial number: 0000009739436
Coding: 011C52725E29330C03
VCID: 4586F698CC614262AE-8010
Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0124565625
Coding: 011B0EA200390CA10030033280000000
Subsystem 1 - Part No: 8P7 951 177
Component: DWA-Sensor H03 0040
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb
Part No SW: 8F0 035 223 D HW: 8F0 035 223 C
Component: DSP Prem H10 0190
Revision: 00010001 Serial number: 34863000203802
VCID: 214E420838094E42F2-8074
Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb
Part No SW: 8K0 959 792 H HW: 8K0 959 792 D
Component: TSG BF H11 0306
Revision: Serial number: 0000009774871
Coding: 011C52325E29330C03
VCID: 4480EB9CC75B7B6AB9-8010
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 00000000519478
Shop #: WSC 00000 000 00000
VCID: 3460BB5C97FBCBEA09-8060
Address 55: Headlight Range Labels: 8K0-907-357.clb
Part No: 8K0 907 357 B
Component: Dynamische LWR H01 0030
Revision: 00000001 Serial number:
Coding: 0000003
VCID: 3460BB5C57FBCBEA09-8060
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4F0 035 061 K HW: 4F0 035 061
Component: Radio U DAB H45 0074
Revision: AB001007 Serial number: 343K+097541919
Coding: 010103010000000101
VCID: 24404B1C271B5B6A99-8070
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
Part No SW: 8T2 035 666 M HW: 8T2 035 666 E
Component: H-BN-EU H47 0187
Revision: -------- Serial number: 475L4097542197
Coding: 010101030206A1ED45000B1E000000000100
Subsystem 1 - Part No: 8R0 060 884 FC
Component: EUR 2018 2601
Subsystem 2 - Part No SW: 4F0 919 604 HW: 4F0 919 604
Component: DU7 High H43 0306
Serial number: 9356L+091148377
Subsystem 3 - Part No SW: 8T0 919 609 G HW: 8T0 919 609 G
Component: E0380 Bedient H08 0100
Serial number: 00000000422561
Subsystem 4 - Part No: 8R0 906 961 A
Component: CD-Database 1293
2 Faults Found:
03276 - Please Check Software Version Management
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 186
Mileage: 145259 km
Time Indication: 0
Date: 2019.01.27
Time: 10:08:38
Freeze Frame:
Voltage: 12.00 V
03175 - Invalid Data Set
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 186
Mileage: 145259 km
Time Indication: 0
Date: 2019.01.27
Time: 10:08:36
Freeze Frame:
Voltage: 12.00 V
Address 62: Door, Rear Left (J388) Labels:. 8K0-959-795.clb
Part No SW: 8K0 959 795 E HW: 4F0 959 795 L
Component: TSG HL H10 0306
Revision: Serial number: 0000102411050
Coding: 010C12324029370C03
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
Component: TSG HR H10 0306
Revision: Serial number: 0000102410868
End-------------------------(Elapsed Time: 04:06)--------------------------
