Bought a 2006 BUL TFSI last night and Oil pressure light came on on the way home so coasted and got a lift on a flat bed. Top end sounds ok, with likely culprit being the oil pump at 99k.
Engine is coming out this weekend to inspect and see whats what.
Other than a new cam lobe, a HPFP upgrade and cleaning the inlet valves is anything else worth doing now along with the oil pump and maybe a clutch?
Is the balance shaft delete oil pump kit on ebay any good?
Is a sachs Xtend clutch strong enough for the torque from mapping or is the sachs SRE organic needed?
TIA
TIA
