Hold Assist Retrofit.
Has anyone figured out what the access code is for the hill hold function adaptation on facelift cars. I would love to revisit this.
20103 or 24990
A3 8V Facelift Limousine
Those codes don't work for me unfortunately. iirc 20103 would be 'accepted' but would then ask for an unlock code again and 24990 is just rejected.
I will check when im home
Any luck?
Yup still the same codes. Use also 24990 for the coding.
Enter access authorization / login code (20103)
Select adaptation: Set the Auto HOLD function status or Auto HOLD functional status to Always active
Select control unit address 03- ABS
Enter access authorization / login code (24990)
Select adaptation Set Auto Hold Fuse or Auto Hold Function to active
Thanks a lot for checking it out. Ill give it a shot after work.
I assume that your abs is coded correctly, if not then you should also do that.
I finally got this all installed.
Is the function that the parking brake turns on or is it just suppose to hold the actual brake pedal for you? I'm getting the parking brake.
Also when I press the button, nothing happens, however, the light will turn on automatically when I'm in drive only.
Followed the adaptations and long coding but don't think it's functioning correctly as before I did this without the button it would just hold the brake and not the emergency brake.
Sent from my Pixel 2 XL using Tapatalk
When you stand still, press the brake pedal. When you see a green brake light in your cluster then release your pedal.
I just get the parking red brake icon. I have the base model so not sure if my gauge cluster has it
Then something is wrong with your coding or adaption.
I'll try recoding again.
Even prior without the button, there wasn't a green button. Audi might of taken the light out completely since it's not an option in the states.
No it should be the same.
Hello
I made retrofit for my 2015 S3. Is there possibility to deactivate hold assist by push button on center console? There is 3 options on adaptation - always active, last settings and never active. I tried all off those but there is no effect to the button. My old Audi A4 B8 I could deactivate the hold assist by button.
Reactions: rcnacura
Hello
You should be able to deactivate it by pressing the button.
Hello
Mine does the same. I think there might be additional coding some cars need because I cannot disable mine either without vcd. So the button is there but useless.
Can you post what you exactly coded and adaptions you changed?
I did these settings from the PDF.
And the long coding end result.
13FF6A9234200A6D037B030081C629C8562C50C0C08194F7024100588608
Did you perform the function test?
Try to do that.
Try to do that.
So the parking brake is not turning on as before, just the brake is holding as it should.
I did the functional test again.
My guage cluster doesn't have a green park symbol, just the park...however when the car is assist holding, no light turns on.
Lastly, the button still does not function at all with quick or long presses. The light just stays on when the car is in drive - turning off if in park.
Mine have a green light on when the hold assist is on. But no function on the button. When I put the shifter to the park the park brake light is on and the hold assist light is off.
Here's my coding:
31F16BA254212A74037B070041CB698CD62A54C0E08296F7184150788208
Here's my fault codes. I assume most of these are on because I took the battery off when I install the Hold/Hill assist.
Wednesday,14,November,2018,18:14:56:31240
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.9.0.2 (x64)
Data version: 20180927 DS296.0
www.Ross-Tech.com
VIN: WAUZZZ8V4F1118408 License Plate:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 20 22 2B 42 44 52 55 5F
6C A9 BB BC
VIN: WAUZZZ8V4F1118408 Mileage: 76491km-47529miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
20-High Beam Assist. -- Status: OK 0000
22-AWD -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: OK 0000
A9-Struct. Borne Sound -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
Address 01: Engine (J623-CJXC) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 259 A HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0003
Revision: --H13---
Coding: 0A1D00322466010B3004
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ECM20TFS0208V0906259A 001005
ROD: EV_ECM20TFS0208V0906259A.rod
VCID: 3E78E24FA10DBDBAE7-806A
2 Faults Found:
17178 - Databus
U1123 00 [040] - Received Error Message
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 5
Mileage: 76326 km
Date: 2018.11.11
Time: 00:02:39
Engine speed: 1177.25 /min
Normed load value: 27.8 %
Vehicle speed: 0 km/h
Coolant temperature: 6 °C
Intake air temperature: 5 °C
Ambient air pressure: 1020 mbar
Voltage terminal 30: 11.289 V
Unlearning counter according OBD: 34
Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
Drivetrain coordinator: brake fault status-Deceleration sensor not available: No
Drivetrain coordinator: brake fault status-Deceleration sensor malfunction: No
Drivetrain coordinator: brake fault status-ESP system error: No
Drivetrain coordinator: brake fault status-ESP system malfunction due to inaccurate engine torque: No
Drivetrain coordinator: brake fault status-ESP indicates TSK message consistency error: No
Drivetrain coordinator: brake fault status-TSK/ESP handshake error: No
Drivetrain coordinator: brake fault status-ESP automatic engagement malfunction: No
Drivetrain coordinator: brake fault status-Brake light implausible: No
16986 - Insufficient Engine Cooling / Coolant Flow
P00B7 00 [096] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 75603 km
Date: 2018.10.11
Time: 15:25:06
Engine speed: 1714.00 /min
Normed load value: 41.2 %
Vehicle speed: 5 km/h
Coolant temperature: 86 °C
Intake air temperature: 16 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 14.414 V
Unlearning counter according OBD: 12
Engine: operating status: PL
Engine temp. management actuator: raw value: 2107
Engine temperature management actuator: stop open: 138
Engine temperature management actuator: after-run stop: 3956
RVC_SP: 169.06 °
RVC_AV: 131.50 °
RVCPWM: -100.000 %
Readiness: 0000 0000
Address 02: Auto Trans (J743) Labels: 0D9-927-770.clb
Part No SW: 0D9 300 012 L HW: 02E 927 770 AQ
Component: DQ250-6A MQB H53 4517
Revision: 05853104 Serial number: TFK01502161743
Coding: 0014
Shop #: WSC 04742 780 00200
ASAM Dataset: EV_TCMDQ250021 001001
ROD: EV_TCMDQ250021.rod
VCID: 1F463FCB06C7D4B2CC-804A
10 Faults Found:
21153 - Gear 1
P072C 00 [002] - Not Selectable
21154 - Gear 2
P072D 00 [002] - Not Selectable
21155 - Gear 3
P072E 00 [002] - Not Selectable
21156 - Gear 4
P072F 00 [002] - Not Selectable
21157 - Gear 5
P073A 00 [002] - Not Selectable
21158 - Gear 6
P073B 00 [002] - Not Selectable
21159 - Gear R
P072B 00 [002] - Not Selectable
10731 - Valve 3 in Transmission Part 1
P174A 00 [002] - Electrical malfunction
10732 - Valve 3 in Transmission Part 2
P174E 00 [002] - Electrical malfunction
10906 - Cooling Oil Valve
P179D 00 [002] - Electrical Malfunction
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 3Q0 907 379 R HW: 3Q0 907 379 G
Component: ESC H42 0711
Revision: 00000000 Serial number: 63554000002190
Coding: 31F16BA254212A74037B070041CB698CD62A54C0E08296F7184150788208
ASAM Dataset: EV_Brake1UDSContiMK100IPB 034036
ROD: EV_Brake1UDSContiMK100IPB_034_AU37.rod
VCID: 49928193E8C30A0242-801C
1 Fault Found:
32951 - Control Module for Electronic Parking Brake
C10E2 54 [008] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 99
Mileage: 76491 km
Date: 2018.11.14
Time: 18:07:49
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AJ HW: 5Q0 937 084 AJ
Component: BCM MQBAB H H18 0137
Serial number: 01011504402415
Coding: 04051B46C2C122F503804004B11807A8080E000000000000000000000000
ASAM Dataset: EV_BCMCONTI 013000
ROD: EV_BCMBOSCH_013.rod
VCID: 00045CB79B790B4AD5-8054
Control Unit For Wiper Motor:
Subsystem 1 - Part No SW: 8V1 955 119 C HW: 8V1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS371 150215 042 0585
Serial number: 150218100849
Coding: 0E47F7
Rain Light Recognition Sensor:
Subsystem 2 - Part No SW: 8U0 955 559 C HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0004
Serial number: 63246980
Coding: 02005D
Light switch:
Subsystem 3 - Part No SW: 8V0 941 531 AD HW: 8V0 941 531 AD
Component: E1 - LDS MQB H05 0032
Serial number: 13 04 2016 00001490
Sensor For Anti Theft Alarm System:
Subsystem 4 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY150231MWH
Alarm horn:
Subsystem 5 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000031865424
6 Faults Found:
197904 - Central Locking
B140A 4B [008] - Over temperature
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 73
Mileage: 75838 km
Date: 2018.10.26
Time: 16:37:31
202506 - Motor for Central Locking of Rear Trunk/Hatch
B12DD 15 [009] - Open or Short to Plus
Freeze Frame:
Fault Priority: 4
Fault Frequency: 8
Reset counter: 58
Date: 2000.00.00
Time: 00:00:00
204290 - Remote key 1
B1479 18 [008] - Current Too Low
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 78
Mileage: 75595 km
Date: 2018.10.10
Time: 14:13:41
565764 - LED Light Bar
B1664 31 [009] - No Signal
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 19
Mileage: 75595 km
Date: 2018.10.10
Time: 14:10:18
929796 - Light Switch
U110B 00 [008] - No Communcations
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 91
Date: 2000.00.00
Time: 00:00:00
930056 - Light Switch
B126A 29 [008] - Signal Implausible
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 91
Mileage: 75595 km
Date: 2018.10.10
Time: 14:11:45
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
Part No SW: 5Q0 919 298 G HW: 5Q0 919 298
Component: PARKHILFE PLA H12 0051
Revision: -------- Serial number: 39491435301627
Coding: 0010160051
ASAM Dataset: EV_EPHVA2CAU3700000 003019
ROD: EV_EPHVA2CAU3700000_003.rod
VCID: 438E93BBCAEFD05288-8016
1 Fault Found:
13637426 - Databus
U1123 00 [008] - Received Error Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 91
Mileage: 76326 km
Date: 2018.11.11
Time: 00:02:40
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-567.clb
Part No SW: 5Q0 907 567 N HW: 5Q0 907 567 N
Component: ACC3 H10 0400
Serial number: 05021503091370
Coding: 003E1301FE0309
ASAM Dataset: EV_ACCBoschMQB 001024
ROD: EV_ACCBoschMQB_AU37.rod
VCID: 46888AAFF9DDE57AAF-8012
6 Faults Found:
1043 - Automatic Distance Control
B10E7 F0 [040] - Disconnected
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 92
Mileage: 76326 km
Date: 2018.11.11
Time: 00:02:40
Control Module temperature: 1 °C
Voltage terminal 15: 11.3 V
Vehicle speed: 0.00 m/s
Acceleration: 0.00 m/s²
1058 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 91
Mileage: 76326 km
Date: 2018.11.11
Time: 00:02:40
1059 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 91
Mileage: 76326 km
Date: 2018.11.11
Time: 00:02:40
1062 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 91
Mileage: 76326 km
Date: 2018.11.11
Time: 00:02:40
1077 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 91
Mileage: 76326 km
Date: 2018.11.11
Time: 00:02:40
1078 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 91
Mileage: 76326 km
Date: 2018.11.11
Time: 00:02:41
Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 AC HW: 5Q0 907 530 M
Component: GW MQB High 212 2203
Revision: -------- Serial number: 13021510802159
Coding: 030100043F085A005B0002781C0B00000001010000000000000000000000
ASAM Dataset: EV_GatewConti 011020
ROD: EV_GatewConti_011_VW37.rod
VCID: 72E0067FA5D529DAD3-8026
Alternator:
Multi Function Steering Wheel Control Module:
Subsystem 2 - Part No SW: 8U0 951 528 A HW: 8U0 951 528 A
Component: E221 - MFL H02 0014
Serial number: 01 11 2014 A0003457
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 H HW: 5Q0 915 181 H
Component: J367-BDMConti H02 1011
Serial number: 74185703001502175498
1 Fault Found:
131699 - Control unit for information electronics 1
U1054 00 [008] - No Communication
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Reset counter: 91
Mileage: 76326 km
Date: 2018.11.11
Time: 11:18:37
Supply voltage: Terminal 30: 12.1 V
Terminal 15: OFF
Address 5F: Information Electr. (J794) Labels:| 8V0-035-MIB-STD1.clb
Part No SW: 8V0 035 840 B HW: 8V0 035 840 B
Component: MU-S--ER 041 0420
Serial number: A3E01702151286
Coding: 01730100FF0A000011110001000A00002F0002040100010000
ASAM Dataset: EV_MUStd6C3PASE 002020
ROD: EV_MUStd6C3PASE.rod
VCID: 346CC0679F4167EA01-8060
Display unit 1 for multimedia system:
Subsystem 1 - Part No SW: 8V0 919 603 C HW: 8V0 919 603 C
Component: DU Std H49 0014
Serial number: AUZ8Z9EY309DFX
Multimedia Operating Unit:
Subsystem 2 - Part No SW: 8V0 919 614 Q HW: 8V0 919 614 Q
Component: ControlUnit_B H41 0054
Serial number: C1000011121400030238
1 Fault Found:
1564 - Microphone 1
B129B 13 [008] - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 14
Reset counter: 97
Mileage: 75838 km
Date: 2018.10.27
Time: 13:46:56
Voltage terminal 30: 14.6 V
Here's my coding:
www.Ross-Tech.com
6C A9 BB BC
Revision: --H13---
2 Faults Found:
17178 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Mileage: 76326 km
Date: 2018.11.11
Time: 00:02:39
P00B7 00 [096] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 75603 km
Date: 2018.10.11
Time: 15:25:06
RVC_SP: 169.06 °
RVC_AV: 131.50 °
RVCPWM: -100.000 %
Coding: 0014
10 Faults Found:
21153 - Gear 1
21154 - Gear 2
21155 - Gear 3
21156 - Gear 4
21157 - Gear 5
21158 - Gear 6
21159 - Gear R
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 99
Mileage: 76491 km
Date: 2018.11.14
Time: 18:07:49
Address 05: Acc/Start Auth. (J518) Labels:| 5Q0-959-435.clb
Part No SW: 5Q0 959 435 A HW: 5Q0 959 435
Component: VWKESSYMQB 021 0604
Revision: 00021000 Serial number: 0360422835
Coding: 030C0C
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_KessyHellaMQBAB 002011
ROD: EV_KessyHellaMQBAB_002.rod
VCID: 3A70EE5FBD25919ADB-806E
No fault code found.
Address 08: Auto HVAC (E87) Labels:| 8V0-820-043.clb
Part No SW: 8V0 820 043 D HW: 8V0 820 043 D
Component: AC Automat H13 0060
Revision: 20027000 Serial number: 00000000574323
Coding: 03000004000000011000000000001100
ASAM Dataset: EV_AirCondiFrontVaAU37X 008020
ROD: EV_AirCondiFrontVaAU37X.rod
VCID: 336EC37B9A4F60D218-8066
Relative humidity sensor in fresh air intake duct:
Subsystem 1 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0003
Serial number: 4F180397000000000001
Coding: 0E47F7
Coding: 02005D
Light switch:
Alarm horn:
6 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 73
Mileage: 75838 km
Date: 2018.10.26
Time: 16:37:31
Freeze Frame:
Fault Priority: 4
Fault Frequency: 8
Reset counter: 58
Date: 2000.00.00
Time: 00:00:00
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 78
Mileage: 75595 km
Date: 2018.10.10
Time: 14:13:41
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 19
Mileage: 75595 km
Date: 2018.10.10
Time: 14:10:18
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 91
Date: 2000.00.00
Time: 00:00:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 91
Mileage: 75595 km
Date: 2018.10.10
Time: 14:11:45
Coding: 0010160051
1 Fault Found:
13637426 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 91
Mileage: 76326 km
Date: 2018.11.11
Time: 00:02:40
6 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 92
Mileage: 76326 km
Date: 2018.11.11
Time: 00:02:40
1058 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 91
Mileage: 76326 km
Date: 2018.11.11
Time: 00:02:40
1059 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 91
Mileage: 76326 km
Date: 2018.11.11
Time: 00:02:40
1062 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 91
Mileage: 76326 km
Date: 2018.11.11
Time: 00:02:40
1077 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 91
Mileage: 76326 km
Date: 2018.11.11
Time: 00:02:40
1078 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 91
Mileage: 76326 km
Date: 2018.11.11
Time: 00:02:41
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 5Q0 959 655 AB HW: 5Q0 959 655 AB
Component: AirbagVW20 014 0385
Serial number: 003MMR02YD71
Coding: 98CCC0000C0000005C5400CA004800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002130
ROD: EV_AirbaVW20SMEVW37X.rod
Side Sensor Driver Front:
Subsystem 1 - Part No SW: ----------- HW: 480 001 202 15
Component: SideSensor_Df 001 0887
Serial number: 35767000000F49C8231$
Coding: 2D2D2D
Side Sensor Passenger Front:
Subsystem 2 - Part No SW: ----------- HW: 480 001 202 15
Component: SideSensor_Pf 001 0887
Serial number: 35867000000359C8231T
Coding: 2D2D2D
Side Sensor Driver Rear:
Subsystem 3 - Part No SW: ----------- HW: 480 400 502 15
Component: SideSensor_Dr 001 6149
Serial number: 3516502BF1901D961215
Coding: 2D2D2D
Side Sensor Passenger Rear:
Subsystem 4 - Part No SW: ----------- HW: 480 400 502 15
Component: SideSensor_Pr 001 6149
Serial number: 3526502A7196FF5322CO
Coding: 2D2D2D
Front Sensor Driver:
Subsystem 5 - Part No SW: ----------- HW: 480 400 801 15
Component: FrontSensor_D 001 6149
Serial number: 3556502B51901DA3E32C
Coding: 2D2D2D
Pedestrian Protection Driver:
Subsystem 6 - Part No SW: ----------- HW: 480 400 601 15
Component: PedP_Sensor_D 001 6149
Serial number: 2286502A9196FF64C16X
Coding: 2D2D2D
Pedestrian Protection Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 400 601 15
Component: PedP_Sensor_P 001 6149
Serial number: 2296502B3196FF64D38Y
Coding: 2D2D2D
Pedestrian Protection Driver 2:
Subsystem 8 - Part No SW: ----------- HW: 480 002 211 14
Component: PedPSensor_D2 001 0887
Serial number: I0M80000000DF511F11E
Coding: 2D2D2D
Pedestrian Protection Passenger 2:
Subsystem 9 - Part No SW: ----------- HW: 480 002 211 14
Component: PedPSensor_P2 001 0887
Serial number: I0N8000000093548B115
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels:| 5Q0-953-549.clb
Part No SW: 8V0 953 521 CS HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 26071304400309
Coding: E218
ASAM Dataset: EV_SMLSKLOMQB 017001
ROD: EV_SMLSKLOMQB_012_AU37.rod
VCID: 0D1A7583DC2B5622AE-8058
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 8V0 920 871 D HW: 8V0 920 871 D
Component: KOMBI H02 4292
Coding: 078D181A2F9000080B81AE001000000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009046
ROD: EV_DashBoardVDDMQBAB_009_VW37.rod
VCID: 3D7AE543AC0BA6A2FE-8068
Alternator:
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Reset counter: 91
Mileage: 76326 km
Date: 2018.11.11
Time: 11:18:37
Terminal 15: OFF
Address 20: High Beam Assist. (J844) Labels:| 8X0-857-511.clb
Part No SW: 8V0 857 511 HW: 8V0 857 511
Component: FLA H03 0002
Revision: AA001001
Coding: 02018764747464545425363E00
Shop #: WSC 06385 790 00021
ASAM Dataset: EV_HighBeamAssisAU37X 001009
ROD: EV_HighBeamAssisAU37X.rod
VCID: 79F23153F8A35A8292-802C
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 D HW: 0CQ 525 130
Component: Haldex4Motion H52 7082
Serial number: HA1-00028.01.15
Coding: 0001
ASAM Dataset: EV_AllWheelContrHA1VW37X 002013
ROD: EV_AllWheelContrHA1VW37X.rod
Address 2B: Steer. Col. Lock (J764) Labels:* 5Q0-905-861.clb
Part No SW: 5Q0 905 861 A HW: 5Q0 905 861 A
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000028975001
Coding: 5D00000000000000
ASAM Dataset: EV_ELVMarquMQB 004111
ROD: EV_ELVMarquMQB.rod
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 D HW: 5Q0 959 593 B
Component: TSG FS 020 0028
Serial number: 250115BAP04634
Coding: 001C9E204000040000001003
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 428096BFD5F5D95A83-8016
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 3Q0 909 144 H HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5061
Coding: 8303
ASAM Dataset: EV_SteerAssisMQB 012140
ROD: EV_SteerAssisMQB_012_VW37.rod
VCID: 3776F76B8E378CF224-8062
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 D HW: 5Q0 959 592 B
Component: TSG BFS 020 0028
Serial number: 070215BB614411
Coding: 001C96204000040000001003
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 418299B3D0F3C2429A-8014
Address 55: Headlight Range (J431) Labels:| 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0080
Revision: -------- Serial number: --------------
Coding: 01A8000001000000
ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110
ROD: EV_HeadlRegulVWLWRMQB.rod
VCID: 75EA3D63D4BB3EE2F6-8020
1 Fault Found:
1564 - Microphone 1
Freeze Frame:
Fault Priority: 4
Fault Frequency: 14
Reset counter: 97
Mileage: 75838 km
Date: 2018.10.27
Time: 13:46:56
Address 6C: Back-up Cam. (J772) Labels:| 5Q0-907-441.clb
Part No SW: 5Q0 907 441 A HW: 5Q0 907 441 A
Component: MQB RVC Mid H07 0140
Coding: 027300010201000300
ASAM Dataset: EV_2CamSysRearPASE 006016
ROD: EV_2CamSysRearPASE_AU37.rod
VCID: 3064CC776B595BCA65-8064
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 8V0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0012
Serial number: 150204200551
ASAM Dataset: EV_SoundActuaGen2AU64X 003010
ROD: EV_SoundActuaGen2AU64X.rod
VCID: 7DFA2543EC8B66A2BE-8028
Address BB: Door Rear Drv (J388) Labels:* None
Part No SW: 5Q0 959 595 D HW: 5Q0 959 595 B
Component: TSG HFS 020 0028
Serial number: 210115BAK0253B
Coding: 000C96204000040000001002
ASAM Dataset: EV_DCURearDriveMAXKLO 006003
ROD: EV_DCURearDriveMAXCONT.rod
VCID: 448C90A7CFE1D76AB1-8010
Address BC: Door Rear Pass (J389) Labels:* None
Component: TSG HBFS 020 0028
Serial number: 210115BAK02538
ASAM Dataset: EV_DCURearPasseMAXKLO 006003
ROD: EV_DCURearPasseMAXCONT.rod
End-------------------------(Elapsed Time: 05:47)--------------------------
Anyone know why the hold assist button doesn't work? My car has an ACC, is it possible that ACC effect to this button?
Reactions: rcnacura
It shouldn't. I think the wiring harness is different as my buttons lighting is always on, but the indicator light turns on when it's "ready".
My button light (red) is on when the car is moving. When I put the gear park the park button light is on and hold assist button is off. The green light on instrument cluster is on when the car is not moving and hold assist is enabled, when the car moving green light disappear like it should. My old Audi A4 b8 it works same but my S3 I can't disable hold assist by button. That's annoying me when I park the car and hold assist is always on.
On adaptation there is three options:
always active
last settings
never active
Should there be a option:
activate by button
always active
last settings
never active
activate by button
Last time I did this without a button I could of sworn the button option was there. I have the same button light behavior as you too.
I'll keep trying to look for the other info.
I'm trying too. If you found a conclusion please reply here, I will do the same.
Reactions: rcnacura
How did people get the wiring through the firewall? I can't see any way of getting it through without completely stripping the dashboard.
AAAdK-xhjNG7TD3zq1L18Mzca
Hers’s my solution. I put it behind the brake pedal (a bit upper left) there is a rubber sealing behind the filling or what I can call it? I made small hole to the rubber and put the duct tape engine side to seal the hole.
So, you can enable this even without the button? Using VCDS I take it? Anyone have more info?
Reactions: sentinal13
22
6K
13
49
5K
