Alarm issues
Shaun2017
Poole, Dorset
Hey guys, so ive just had my cluster repaired by a specialist company, all they did was put in a new lcd and change a couple of leds.
Since reinstalling last night, everytime i lock the car the hazards go crazy and blink rapidly.
What could be causing this?
May also be worth noting the alarm doesnt sound and the lights blink as soon as i lock the car, but they stop after 5 mins and dont flash again
Two faults i guess.
One, your alarm siren is faulty, so infact the whole alarm is going off, and only the indicators are flashing. Very common for the siren on these cars to have failed by now.
Two, if its an early facelift car, the cluster has a connection back to the alarm system. I've had the issue a few times where a PFL cluster in an early facelift car cuases the alarm to go off immediately after locking, due to this connection. PFL's didnt have it.
I would unplug the cluster and see if the issue continues. If it goes away, then i can find out what wire you need to cut to fix it.
For that to be the case, it sorta implies they did more than just swap the LCD though...
I removed the cluster and it worked...no flashing lights...if i cut a cable will it screw up the alarm or immobilizer in anyway?
He did say that when he took it apart someone had screwed up the insides and had used bulbs and not leds, so he replaced them back to leds and said it was all working. Thats as much as i know regarding what they did
nope, just stops the false triggering...
I think it the Green connector, pin 12, blue/purple wire.
This only applies if its a early facelift car with an analog clock...
Yer its the analogue clock, i took a photo for you to confirm before i go snipping cables
Just a random question to add, if i get a new alarm system as mine is well......up the creak. Is this going to cause them any issues
shouldnt do, no. You just need to fit a new siren, they're cheap enough on ebay and the newer type is much more reliable than the original one :)
I did consider that and then i vag-com the car and all the interior sensors are not working as well. Could that be a simple fix
Thursday,27,July,2017,10:41:33:57456
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 17.1.3.0
Data version: 20170320 DS267.7
www.Ross-Tech.com
VIN: License Plate: SM FULL
Mileage: 253650km-157610mi Repair Order:
Chassis Type: 8D - Audi A4/S4/RS4 B5 (1995 > 2002)
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
Mileage: 253650km-157610miles
Address 01: Engine Labels: 059-907-401-AKE.clb
Part No: 8D0 907 401 F
Component: 22.5l/4VT EDC 0000SG D61
Coding: 02002
Shop #: WSC 06325
VCID: 275D4714C50D647988-4AEC
3 Faults Found:
00575 - Intake Manifold Pressure
08-10 - Control Limit Surpassed - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-00 -
00626 - Glow Plug Indicator Light (K29)
31-00 - Open or Short to Ground
Readiness: N/A
Address 03: ABS Brakes Labels: 8E0-614-111-ASR.lbl
Part No: 8E0 614 111 AH
Component: ABS/ASR 5.3 FRONT D10
Coding: 00012
Shop #: WSC 00028
VCID: 64C71018F4BBCF616D-5140
1 Fault Found:
01203 - Electrical Connection between ABS and Instrument Cluster
31-10 - Open or Short to Ground - Intermittent
Address 08: Auto HVAC Labels: 8D0-820-043-1D.lbl
Part No: 8D0 820 043 M
Component: A4 KLIMAAUTOMAT D57
Coding: 00041
Shop #: WSC 06325
VCID: 2A5BBE20D61F591197-2594
No fault code found.
Address 15: Airbags Labels: 8D0-959-655-AI8.lbl
Part No: 8D0 959 655 J
Component: Airbag Front+Seite 0001
Coding: 00106
Shop #: WSC 06325
VCID: 3D71857C3791DEA9C2-517A
1 Fault Found:
01217 - Side Airbag Igniter; Driver Side (N199)
32-00 - Resistance Too High
Address 17: Instruments Labels: 8D0-919-xxx-17.lbl
Part No: 8D0 919 930 M
Component: B5-KOMBIINSTR. VDO D15
Coding: 05460
Shop #: WSC 00000
VCID: 387F946818B3FB8111-5122
Subsystem 1 - Part No: IMMO
Component: IDENTNR: AUZ7Z0X0968827
IMMO-IDENTNR: AUZ7Z0X0968827
4 Faults Found:
00771 - Fuel Level Sensor (G)
30-10 - Open or Short to Plus - Intermittent
01128 - Immobilizer Pickup Coil (D2)
35-10 - - - Intermittent
01176 - Key
07-10 - Signal too Low - Intermittent
00779 - Outside Air Temp Sensor (G17)
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8D0 862 257 E
Component: CV-Pump, Alarm, RC D13
Coding: 13130
Shop #: WSC 01238
VCID: 2F6DAF34EDFD3C3940-4ECE
10 Faults Found:
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01372 - Alarm triggered by Door Contact Switch; Rear Passenger Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01366 - Opened Due to Crash Signal
35-00 - -
01365 - Lock/Unlock Switch; Interior
29-00 - Short to Ground
00991 - Interior Lights
28-00 - Short to Plus
00955 - Key 1
09-00 - Adaptation Limit Surpassed
01134 - Alarm Horn (H12)
49-00 - No Communications
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00102
Shop #: WSC 06325
VCID: 60CF1C08E0A3D34189-4B1C
7 Faults Found:
01377 - Ultra Sonic Sensor for Alarm System; Left (G170)
27-10 - Implausible Signal - Intermittent
01378 - Ultra Sonic Sensor for Alarm System; Right (G171)
01403 - Glass-Break Sensors; Rear
36-00 - Open Circuit
01380 - Alarm triggered by Anti-Theft Sensor; Rear Left
35-00 - -
01381 - Alarm triggered by Anti-Theft Sensor; Rear Right
35-00 - -
01382 - Alarm triggered by Anti-Theft Sensor; Front Left
35-00 - -
01383 - Alarm triggered by Anti-Theft Sensor; Front Right
35-00 - -
End-------------------------(Elapsed Time: 04:37)--------------------------
you really need to clear all the codes and see what comes back.
Lots of intermittent codes which might be ancient!
Hi buddy, i cleared all the codes and rescanned here's the new list
Friday,28,July,2017,10:40:36:57456
www.Ross-Tech.com
VIN: License Plate: SM FULL 2
Mileage: 253660km-157617mi Repair Order:
Mileage: 253660km-157617miles
Coding: 02002
Shop #: WSC 06325
VCID: 275D4714C50D647988-4B04
Readiness: N/A
Coding: 00012
Shop #: WSC 00028
1 Fault Found:
Shop #: AUTOMAT D57
VCID: 2A5BBE20D61F591197-259A
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Coding: 00106
Shop #: WSC 06325
VCID: 3D71857C3791DEA9C2-5198
2 Faults Found:
01218 - Side Airbag Igniter; Passenger Side (N200)
Coding: 05460
Shop #: WSC 00000
Coding: 13130
Shop #: WSC 01238
VCID: 2F6DAF34EDFD3C3940-4EEA
1 Fault Found:
Coding: 00102
Shop #: WSC 06325
VCID: 60CF1C08E0A3D34189-4B04
7 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
End-------------------------(Elapsed Time: 05:49)--------------------------
you need to log into the interior monitoring module and clear its codes, theres still stuff there that should have gone, like the "alarm triggered by anti-theft sensor" codes....
9
687
599
