Bad brakes and fault code
Oranoco
HertFORDshire
Website
www.passionford.com
Decided to take the A4 for a spin an the brakes feel awful with quite a hard pedal and little power. Scanned it and get a fault code saying the Abs unit can't communicate. Tried to clear the code but it just comes back up. Thought I noted the code but can't see it so will need to update later when I scan it again
Any ideas? Have a spare in my 99 donor car if it's compatible.
This is not what's wanted when I'm trying to go faster
Reactions: Browett1982
Sitting here with a Snap On scanner and getting P1851 Data bus missing, missing message from ABS ecu.
Could this be the Golf ECU not talking to my Abs?
Don't think the servo is getting any vacuum as 1 way valve is stuffed. Pulled the pipe off while fiddling and found no pressure. VCDS is talking to the ABS module and says no faults, even ran through test sequences without a problem.
Yes it should but it just doesn't seem to be getting to the servo. The donor car hasn't run since April but there was still vacuum present when I popped the hose.
Code is just a ghost from the new ecu.
You can bypass the one way valve for testing, just don't produce any boost.
Valve was dead and the hose had several hairline cracks on the concertina elbow. New pipe and valve on and it stands on its nose.
Reactions: Andyb5tdi
8K
943
15
25K
