anything I need to watch out for?
ive put my VCDS cable on it and there is an error on the steering assist. but it was about 2 months ago and flagged as intermittent priority 6.
it seems to drive well enough and I wonder if the code is because the battery has run flat at some point?
also I checked the vin number and it seems it has had its ecu updated to fix the emissions scandal. what negative effects will this produce? as I did notice some almost as if it was going to stall episodes when stopping at junctions, you could feel the rpm dropping.
the only error was this:
Address 44: Steering Assist (J500) Labels: 8K0-909-144.clb
Part No SW: 8K0 909 144 F HW: 8K0 909 144 B
Component: RCEPS H37 0507
Revision: 00001000 Serial number: 0002697590
Coding: 100000000001
Shop #: WSC 00976 210 89512
ASAM Dataset: EV_RCEPSAU48X 008014
ROD: EV_RCEPSAU48X_008.rod
VCID: 34677AF59FEAFCE13D-8060
1 Fault Found:
2305 - Function Restriction due to Start Voltage Interruption
U1410 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 2
Reset counter: 21
Mileage: 97426 km
Date: 2017.03.30
Time: 15:42:52
valid
1 Fault Found:
U1410 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 21
Mileage: 97426 km
Date: 2017.03.30
Time: 15:42:52
valid
