Park Assist (PLA) Coding
Does anyone has the exact PLA coding , i am driving an A3 Pre FL - upgraded to MIB2 , everything is working fine till i fitted the PLA 3.0
1) Rear buzzer does not sound anymore whenever i engage the reverse gear
2) sometime when engage the reverse gear , PLA image show up instead of my reverse camera
Seems like an issue with reverse camera LOW on in mmi.. Hed very simular issues.
You need to update your gateway i had the same issue
Verzonden vanaf mijn iPhone met Tapatalk
i assume that car 2D image will appear when some obstacle/object is near to it , but what i hear is only buzzer but mmi did not show up any image - is that normal ?
Need to update the gateway then it will works fine
i do have this error on my ABS
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 614 517 BJ HW: 5Q0 614 517 AG
Component: ESC H62 0636
Revision: 00000000 Serial number: 61466000003170
Coding: 13F18AA22421126F897F0E0441CC29C851244891708294730221500A060802
Shop #: WSC 00046 000 00000
ASAM Dataset: EV_Brake1UDSContiMK100IPB 035019
ROD: EV_Brake1UDSContiMK100IPB_035_VW37.rod
VCID: 7AB8FAA2FD26FB565D-802E
1 Fault Found:
8307 - Databus
U1122 00 [009] - Implausible Message
[FCAN: PLA_Status_PLA_ESP signal is invalid]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 3
Fault Frequency: 13
Reset counter: 57
Date: 2020.09.08
Time: 13:29:59
VCDS log
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
65-Tire Pressure -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
Address 01: Engine (J623-CZCA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 027 HB HW: 04E 907 309 BH
Component: R4 1.4l TFS H25 4418
Revision: R7H25---
Coding: 02250032232401082000
Shop #: WSC 29277 002 1048576
ASAM Dataset: EV_ECM14TFS01104E906027HB 001006
ROD: EV_ECM14TFS01104E906027HB.rod
VCID: 6B96CFE6827C52DED6-803E
CAN Converter 01:
No fault code found.
Readiness: 0110 0001
Address 02: Auto Trans (J743) Labels: 0CW-927-769.clb
Part No SW: 0CW 300 049 J HW: 0AM 927 769 E
Component: GSG DQ200G2_M H05 0905
Revision: 00005006 Serial number: CU501605137744
Coding: 0014
Shop #: WSC 17734 418 534600
ASAM Dataset: EV_TCMDQ200021 001001
ROD: EV_TCMDQ200021_VW31.rod
VCID: 44C4445ACF627DA677-8010
1 Fault Found:
8307 - Databus
Freeze Frame:
Fault Priority: 3
Fault Frequency: 6
Reset counter: 58
Date: 2020.09.09
Time: 16:51:14
Address 08: Auto HVAC (E87) Labels:| 8V0-820-043.clb
Part No SW: 8V0 820 043 C HW: 8V0 820 043 C
Component: AC Automat H14 0060
Revision: 20028000 Serial number: 00000000942368
Coding: 03100004110000001000000000001400
ASAM Dataset: EV_AirCondiFrontVaAU37X 008020
ROD: EV_AirCondiFrontVaAU37X.rod
VCID: 3228128265D6C316D5-8066
Relative humidity sensor in fresh air intake duct:
Subsystem 1 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0005
Serial number: A8584C2800PAG0MUFU01
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 CL HW: 5Q0 937 084 AN
Component: BCM MQBAB H H24 0175
Serial number: 01061614400337
Coding: 07041A42C24122F543804004001807A80000000000000000000000000000
ASAM Dataset: EV_BCMMQB 015001
ROD: EV_BCMBOSCH_015.rod
VCID: 0444845A8FE2BDA637-8050
Control Unit For Wiper Motor:
Subsystem 1 - Part No SW: 8V2 955 119 C HW: 8V2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS371 160503 043 0585
Serial number: 160517071625
Coding: 0A47F7
Rain Light Recognition Sensor:
Subsystem 2 - Part No SW: 8U0 955 559 C HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0004
Serial number: 61860977
Coding: 00006C
Light switch:
Subsystem 3 - Part No SW: 8V0 941 531 AD HW: 8V0 941 531 AD
Component: E1 - LDS MQB H05 0032
Serial number: 04 03 2016 00001534
1 Fault Found:
197644 - Control Circuit for Fuel Tank Flap
B1263 01 [009] - Electrical Failure
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 57
Date: 2000.00.00
Time: 00:00:00
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
Part No SW: 5QA 919 298 D HW: 5QA 919 298 A
Component: PLA 3.0 12KH07 0050
Serial number: 000308417318353
Coding: 0270061051
ASAM Dataset: EV_EPHVA2CAU3700000 009041
ROD: EV_EPHVA2CAU3700000_009_AU37.rod
VCID: 51EA7D0E0010980ECC-8004
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 5Q0 959 655 AB HW: 5Q0 959 655 AB
Component: AirbagVW20 015 0388
Serial number: 003MMR1T9NJQ
Coding: 98CCC000000000005C54000000C800000065
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_AirbaVW20SMEVW37X 002130
ROD: EV_AirbaVW20SMEVW37X_VW48.rod
VCID: 004C884A9BFAA18613-8054
Side Sensor Driver Front:
Subsystem 1 - Part No SW: ----------- HW: 480 002 105 16
Component: SideSensor_Df 001 0887
Serial number: 35767000000E3430BB1W
Coding: 2D2D2D
Side Sensor Passenger Front:
Subsystem 2 - Part No SW: ----------- HW: 480 002 105 16
Component: SideSensor_Pf 001 0887
Serial number: 3586700000082430BB1Q
Coding: 2D2D2D
Side Sensor Driver Rear:
Subsystem 3 - Part No SW: ----------- HW: 480 401 805 16
Component: SideSensor_Dr 001 6149
Serial number: 3516502BB2076342425-
Coding: 2D2D2D
Side Sensor Passenger Rear:
Subsystem 4 - Part No SW: ----------- HW: 480 401 805 16
Component: SideSensor_Pr 001 6149
Serial number: 3526502AF20763449052
Coding: 2D2D2D
Front Sensor Driver:
Subsystem 5 - Part No SW: ----------- HW: 480 401 105 16
Component: FrontSensor_D 001 6149
Serial number: 3556502992057291C365
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels:| 5Q0-953-549.clb
Part No SW: 5Q0 953 549 E HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0140
Revision: -------- Serial number: 11061804680124
Coding: A018
Shop #: WSC 27213 003 1048576
ASAM Dataset: EV_SMLSKLOMQB 020002
ROD: EV_SMLSKLOMQB_019_AU37.rod
VCID: 3E3036B2A18E177621-806A
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 8V0 920 871 R HW: 8V0 920 871 R
Component: KOMBI H03 6423
Coding: 67AD19882A9008080101EE001000000000000000
Shop #: WSC 00046 123 12345
ASAM Dataset: EV_DashBoardVDDMQBAB 009051
ROD: EV_DashBoardVDDMQBAB_009_VW37.rod
VCID: 4BD66F66E23CB2DEB6-801E
2 Faults Found:
13636608 - Control Module Incorrectly Coded
U1014 00 [009] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 58
Mileage: 41805 km
Date: 2020.09.09
Time: 16:55:58
16776980 - Databus
U1121 00 [009] - Missing Message
[PLA_Status_01 keine Kommunikation]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 57
Mileage: 41805 km
Date: 2020.09.09
Time: 16:55:58
Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 AJ HW: 5Q0 907 530 M
Component: GW MQB High 212 2246
Revision: -------- Serial number: 25051610800074
Coding: 030100043F0857005B000248180B00000001010000000000000000000000
ASAM Dataset: EV_GatewConti 013020
ROD: EV_GatewConti_013.rod
VCID: 79BAE5AEF820F04E54-802C
Alternator:
Multi Function Steering Wheel Control Module:
Subsystem 2 - Part No SW: 8S0 951 523 C HW: 8S0 951 523 C
Component: J453 MFL H07 0002
Serial number: 20170719083548 00758
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 H HW: 5Q0 915 181 H
Component: J367-BDMConti H02 1011
Serial number: 74185704001605211169
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 E HW: 5Q0 959 593 B
Component: TSG FS 020 0041
Serial number: 110516EE90176A
Coding: 001E0B205C01040000001002
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 43C64746CA6C7A9E4E-8016
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 5Q0 909 144 AB HW: 5Q0 909 144 AA
Component: EPS_MQB_ZFLS 130 1082
Coding: 830F0000
ASAM Dataset: EV_SteerAssisMQB 015157
ROD: EV_SteerAssisMQB_015.rod
VCID: 74A4D49ADF428D2607-8020
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 E HW: 5Q0 959 592 B
Component: TSG BFS 020 0041
Serial number: 080516EE406587
Coding: 001C03205E01040000001002
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 42C84242D576739645-8016
Address 55: Headlight Range (J431) Labels:| 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0080
Revision: -------- Serial number: --------------
Coding: 019E000001000000
ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110
ROD: EV_HeadlRegulVWLWRMQB.rod
VCID: 75A2E99ED438942E30-8020
Address 5F: Information Electr. (J794) Labels:* Redir Fail!
Part No SW: 8V1 035 035 C HW: 8V1 035 035 C
Component: MU-P-LND-EU 055 1326
Serial number: A698K0JS029728
Coding: 01730107FF0A000011110001000A00106F0027C601700100FE
ASAM Dataset: EV_MUHig4CGen2HBAS 001001
ROD: EV_MUHig4CGen2HBAS_VW37.rod
Data medium:
Subsystem 1 - Part No SW: V03 959 803 BG HW: -----------
Component: ROW 2020/2021 --- 0088
Serial number: --------------------
Display unit 1 for multimedia system:
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0014
Serial number: AUZ8Z9H1Y07S81
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8V0 919 614 BL HW: 8V0 919 614 BL
Component: ControlUnit_H H85 0855
Serial number: ALJAL129061600010793
Compact Disc Database:
Subsystem 4 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2 --- 1017
2 Faults Found:
3073 - Cellular Antenna
B1053 13 [009] - Open Circuit
[GSM/UMTS aerial - open circuit]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 57
Mileage: 41805 km
Date: 2020.09.09
Time: 16:56:40
Voltage terminal 30: 12.5 V
3084 - GSM antenna 2
B1533 13 [009] - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 57
Mileage: 41805 km
Date: 2020.09.09
Time: 16:56:41
Address 65: Tire Pressure (J502) Labels: None
Part No SW: 4M0 907 273 B HW: 4M0 907 273 B
Component: RDKHUFAU736 H04 0010
Serial number: 40000000005092
ASAM Dataset: EV_RDKHUFAU736 002007
ROD: EV_RDKHUFAU736.rod
VCID: 2F2E1BF676E4EEFEBA-807A
Address 6C: Back-up Cam. (J772) Labels:| 5Q0-980-556.clb
Part No SW: 5Q0 980 556 B HW: 5Q0 980 556 B
Component: RVC Compact H12 0231
Coding: 0273010100002003400040
ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 006009
ROD: EV_CamSysRVRVCPANAMQBAB.rod
VCID: 393A25AEB8A0304E14-806C
Address BB: Door Rear Drv (J388) Labels:* None
Part No SW: 5Q0 959 395 E HW: 5Q0 959 395 B
Component: TSG HFS 020 0041
Serial number: 300416EDT03117
Coding: 000C03204001040000001002
ASAM Dataset: EV_DCURearDriveMINKLO 006003
ROD: EV_DCURearDriveMAXCONT.rod
Address BC: Door Rear Pass (J389) Labels:* None
Component: TSG HBFS 020 0041
Serial number: 300416EDT03114
ASAM Dataset: EV_DCURearPasseMINKLO 006003
ROD: EV_DCURearPasseMAXCONT.rod
1 Fault Found:
8307 - Databus
Freeze Frame:
Fault Priority: 3
Fault Frequency: 13
Reset counter: 57
Date: 2020.09.08
Time: 13:29:59
VCDS log
Revision: R7H25---
CAN Converter 01:
Coding: 0014
1 Fault Found:
8307 - Databus
Freeze Frame:
Fault Priority: 3
Fault Frequency: 6
Reset counter: 58
Date: 2020.09.09
Time: 16:51:14
Coding: 0A47F7
Coding: 00006C
Light switch:
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 57
Date: 2000.00.00
Time: 00:00:00
Coding: 0270061051
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: A018
2 Faults Found:
U1014 00 [009] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 58
Mileage: 41805 km
Date: 2020.09.09
Time: 16:55:58
16776980 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 57
Mileage: 41805 km
Date: 2020.09.09
Time: 16:55:58
Alternator:
Coding: 830F0000
Data medium:
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 57
Mileage: 41805 km
Date: 2020.09.09
Time: 16:56:40
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 57
Mileage: 41805 km
Date: 2020.09.09
Time: 16:56:41
I will make a scan of my car tommorow
There should be change of coding for pla 3.0
RVC low on in mmi will give simular issues. But looking at your log i guess you did not undo all changes in all other components when upgrading to pla 3.0. When upgrading pla 2.0 to 3,0 you need to deactivate pla 2.0 and activate pla 3.0 in ABS & Cluster.
All errors:
ABS
Byte 24 , bit 6 needs to be checked.
Byte 27 bit 1 needs to be unchecked..
09 CE (not related)
Tank flap is common issue. Just replace unit. Bought mine on ali...still works after 3 jrs
Instruments 17
byte 5 bit 4 unchecked
byte 13 bit 1 checked.
5F (not related)
installed the LTE antennas in the bumper? There is this issue.
If there is still an issue please update the GW software. Upgrade to AM software..
And next time just upload the error log.
All errors:
ABS
09 CE (not related)
Instruments 17
5F (not related)
thanks mate , before that my car does not have PLA so is not considering as upgrading , is an brand new setup , original only have reverse sensors
will check on my ABS in a while
09 - as car still under agent warranty - thus will get them to change :)
instrument 17
for byte 13 bit 1 is equal to pedestrian protection : BAP distance , YES is currently unchecked
5F
LTE antennas is not in the bumper is , in the passenger glove box
for GW software - is my GW compatible ? where should i download and upgrade ?
In that case:
Did you change rear abs sensors or do you have ACC?
The rear abs sensors need to be replaced, only not when you have ACC.
Coding:
ABS Byte 26
Rear left
Bit 4 checked Bi-Directional Wheel Speed Sensor (Multi-Link Rear Suspension)
Bit 4 & 5 checked Bi-Directional Wheel Speed Sensor (Torsion Bar Rear Suspension)
Rear right
Bit 6 checked Bi-Directional Wheel Speed Sensor (Multi-Link Rear Suspension)
Bit 6 & 7 checked Bi-Directional Wheel Speed Sensor (Torsion Bar Rear Suspension)
Byte 26 is 50 or F0 for all cars with acc and/or Pla
Byte24
Bit 5 PLA3.0 Installed (this needs to be checked)
Bit 6 PLA3.0 related (normally not checked,but leave bit untouched)
Byte27
Bit 1 PLA2 w/ Braking Intervention Installed (this need to be unchecked)
Dont worry about GW software, 1st make sure your coding is correct.
Yes I did change my both rear abs sensors , I do not have acc
will check on my odis in a while for the coding
As not sure why my vcds can’t really edit abs sensors
In that case:
Coding:
ABS Byte 26
Rear left
Rear right
Byte24
Byte27
VCDS/ODIS ABS coding , i did remember clearly after i remove the old ABS sensors and fitted the new ABS sensors - the rear buzzer sound is gone , so i thought that maybe i did not completed my installation , so i continue to setup my installation next day , after completion, same issue
You already upgraded the rear sensors and put 50 into byte 26. (if no error during driving above 70 km/h then you are set, else change to F0)
You coded the cars abs for pla 2.0... not 3.0.
To add pla 3.0:
Change byte 24 from 000000010 to 00100010 (bit 5 checked)
Change byte 27 from 00001010 to 00001000 (bit 1 unchecked)
Abs wil be ok now.
Reactions: d3vilstarz
You have acces to odis?
To add pla 3.0:
Abs wil be ok now.
Thanks mate will give it a try and update
As i can see your car does not come with indirect tire pressure monitorng. (this is a free upgrade if you have vcds:
https://www.audi-sport.net/xf/threads/enabling-tpms-for-a3-s3-8v-experimental.216661/
Also hill hold is a cheap upgrade. As yours does not come with this...
And if you want: ACC is an option because you have GW high. Estimated price arround 350-400 euros depending on dealer cost of removing cp.
I do have both tpms and autohold install , both is working well
Only problem for autohold on my instrument cluster does not have green logo when it is activated , as they mention my instrument cluster is too old to support / activate this green logo :(
To add pla 3.0:
Abs wil be ok now.
ABS Fault code is clear :)
now left with 2 issue
1) when object/obstacle is near , buzzer will sound but no image is appearing in the mmi - as you and some others mention need to upgrade the gateway ?
2) Rear Buzzer does not sound - is this something to do with the upgrade firmware of the gateway ?
Give me a new error log
Interested in 09 17 19 and 5f
Never heard of a cluster too old to support autohold. I guess 1 error in 17 is here.
2nd error should be the pla
Next i want to check 5f for pdc (adaptation and coding)
I saw 1 in 17 in earlier log.
As i have retrofitted vc, i cannot use my coding. Coding of vc is different.
I asked a friend to post his cluster coding pre and post pla. He'll be responding soon.
For the cluster. Mine is a 2013 and the origional cluster supported green autohold light. As does this friends car. I need to compare his and your coding for pla and autohold.
Your car should be error free (gas actuator not)
thanks mate appreciated
Coding: 63AD19882A8008080101EE001001000000000000
for instrument cluster coding , auto hold button light is active
no auto light light appearing in instrument when autohold is active
no pla image when pla is activate
https://forums.ross-tech.com/index.php?threads/19949/
Lots of info here..
The FPK seems to have Byte 5 Bit 4 Active and Byte 13 Bit 0 NOT Active (maybe PLA2.0)
The VDD seems to have Byte 5 Bit 4 NOT Active and Byte 13 Bit 0 Active
My friend is responding on monday as he is rebuilding his car after small accident..
Coding is coming....
ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdc,activated ,60
ENG122227-ENG117500-Car_Function_Adaptations_Gen2-menu_display_pdc_after_disclaimer,not activated ,60
ENG122227-ENG117497-Car_Function_Adaptations_Gen2-menu_display_pdc_clamp_15_off,not activated ,60
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,not activated ,60
ENG122227-ENG117499-Car_Function_Adaptations_Gen2-menu_display_pdc_standstill,not activated ,60
These are on??
These are on??
Yap this option all activated
01730301FF0A000011110001000A00102F002BE5017001009E
5f coding (oem not touched) Search for camera and pdc /pla (camera low must be off)
No errors at all (tank flap not important)
