Done DRL change
Dainiaks
Essex
Just changed ugly yellow drl's on my se model. What you think?
20160624 1355181
20160624 1901481
Reactions: xpoweruk, gary_a4_quattro, spartacus68 and 1 other person
Nice job. Transforms the car. :)!
They do look so much better than the original glow worm bulbs fitted by Audi. I never used to run with the DRL's on till I changed them over to LED's as compared to most cars these days they looked fairly pathetic.
This is a bit of a how to in my build thread.
They are P13W bulbs, you need 4. Cheaper to order from China / Hong Kong but you need to wait a few weeks then.
http://www.ebay.co.uk/itm/2x-Xenon-...ight-DRL-Daytime-Running-Bulbs-/281944493900?
Alright, maybe you can help me out. I've been trying the same thing, but I don't have access to the DRL bulbs??? I can easily change the low/high beam bulbs, because they only have a rubber cap hiding them, but the DRL seems to be hidden behind solid plastic. Can you maybe post a few pictures so I can see how you did it?
I follow thisIMG 2908 zps39ad5334 IMG 2910 zpsc9791349 you have to cut the holes, and cover it after.
Sweet. What did you cover the holes with?
That's easy and cheap. How did you glue the caps to make sure that no moisture goes in the headlight? Did you plastic weld it or did you use silicone?
Much appreciated, thanks!
Np. Can you show your pics if you will do it. Thanks.
570
637
AjM
