- Joined
- Oct 3, 2015
- Messages
- 204
- Reaction score
- 4
- Points
- 18
- Age
- 45
so generally when the car has started from cold its "normally" laggy, its certainly not smooth and normally goes straight to 1400revs for idle and then may take 1 minute to come down to 800revs. but even when this is happening and even if the car goes straight to 800 in random moments, the whole time the idle is lumpy and if you press the throttle it struggles to give some revs and only gets smoother when it gets to around 2.3k.
it also has an issue when you slow down to a junction and you need to get off again, you need to rev the engine a little so that it "wakes up" so to speak for the performance to pull it forward, but again it only happens at low revs.
when its higher revs, it pulls away.
after seeing another forum post on another audi forum, im starting to think its to do with the fuel pressure pump?
