Ignition Switch / Poor Warm Starting Issue?? with VCDS Scan
ryanstewart9
Surrey/Hants/Berks
I'd say for a couple of weeks now I've noticed the car taking longer to crank over when warm, or sometimes only just firing in time before the battery giving up (bit embarrassing on the garage forecourt).
So finally managed to get to scan the car today. Before scanning the car I thought it would be the usual warm start issues of temp/crank sensor, starter motor, weak battery maybe, as the car didn't seem to struggle when starting from cold.
Scan today:
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 021 LG HW: 03G 906 021 AN
Component: R4 2,0L EDC G000SG 9828
Revision: --H07--- Serial number: AUX7Z0GNFN800J
Coding: 0000072
Shop #: WSC 06314 000 00000
VCID: 6FE9B61C7E2EE846BF-803A
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-614-517-MK60AT.clb
Part No SW: 1K0 614 517 AC HW: 1K0 614 517 AC
Component: ESP FRONT MK60-AT 0102
Revision: 00H14001
Coding: 0039554
VCID: 68DBDD005BC03F7EFE-803C
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 AH HW: 8P0 820 043 AH
Component: KlimavollautomatH19 0420
Revision: 115452 Serial number: 8P0820043AH
Shop #: WSC 00000 000 00000
VCID: 72EFBF686D1CC5AE50-8026
Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 K HW: 8P0 907 279 K
Component: Bordnetz-SG H54 2501
Revision: 00H54000 Serial number: 00000007906363
Coding: AD880F21B01410004F0000003000000000195E172101020E000000000000
Shop #: WSC 06314 000 08192
VCID: 458534B40C12021625-8010
Subsystem 1 - Part No: 8P2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 06314
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 L HW: 8P0 959 655 L
Component: Airbag 9.41 H01 4210
Revision: 91H01421 Serial number: 003CP001MJZV
Coding: 0071612
VCID: 4B91028C2A76F466F3-801E
Subsystem 1 - Serial number: 6332DRB406128732C
Subsystem 2 - Serial number: 6342DRB406124C97P
Subsystem 3 - Serial number: 63528RB40324231B6
Subsystem 4 - Serial number: 63628RB40324210C5
Subsystem 5 - Serial number: 63747RB402E394C8Z
Subsystem 6 - Serial number: 63847RB402E393DB$
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0004042
VCID: 418D20A4183A2E3619-8014
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H02 0030
1 Fault Found:
00883 - Ignition Switch (D) Terminal S
012 - Electrical Fault in Circuit - Intermittent
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 981 KX HW: 8P0 920 981 KX
Component: KOMBIINSTR. VDO H22 0660
Revision: D0H22003 Serial number: 2257I003000070
Coding: 0004458
Shop #: WSC 00411 067 57207
VCID: 183BADC02B204FFE8E-804C
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533__Gateway H15 0180
Revision: H15 Serial number: 1400K07B05036F
Coding: E9807F0E4006022103
VCID: 306B7560A390B7BEE6-8064
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H22003 Serial number: AUX7Z0GNFN800J
Shop #: WSC 00411 210 91522
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8P0 035 193 G HW: 8P0 035 193 G
Component: RNS-E PU EU H07 0220
Revision: 0000013S Serial number: AUZBZ7ND201678
Coding: 0209755
VCID: 3463797057888B9E82-8060
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 K HW: 8P0 959 801 K
Component: Tuer-SG H03 0050
Coding: 0000752
VCID: 43812AAC02263C260B-8016
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 M
Component: EPS_ZFLS Kl.079 H08 1901
Shop #: WSC 02069 000 90108
VCID: 3667437841F4998EBC-8062
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 J
Component: KSG H11 0080
Coding: 1880202002186008850D4C8FC637
Shop #: WSC 00515 210 91544
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Subsystem 3 - Part No: 8P0 951 177
Component: Innenraumueberw.H04 0020
2 Faults Found:
00849 - S-contact at Ignition/Starter Switch (D)
008 - Implausible Signal - Intermittent
01565 - Luggage Compartment Light (W3)
007 - Short to Ground - Intermittent
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
Coding: 0000752
VCID: 448329B007283B1E32-8010
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0209755
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 E HW: 8P4 959 801 E
Component: Tuer-SG H04 0040
Coding: 0000208
Shop #: WSC 06314 000 1012557
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 E HW: 8P4 959 802 E
Coding: 0000208
VCID: 428F2FA81D3C352E00-8016
Address 76: Park Assist Labels: 8P0-919-283.lbl
Part No SW: 8P0 919 283 D HW: 8P0 919 283 D
Component: Parkhilfe 4-Kan H09 0070
Revision: 00H09000 Serial number: 00067824830713
Coding: 0000113
VCID: 3C7351507FD843DE4A-8068
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 Q HW: 8P0 862 335 Q
Component: FSE_255x BT H26 0350
Revision: 00000000 Serial number: 00000005274990
Coding: 0011422
End-------------------------(Elapsed Time: 02:08)--------------------------
A quick Google on the net and I'm thinking the Ignition Switch looks like it could be the culprit??
Anyone with any experience with this issue/fault code??
To add to my problems I then tried to start the car to run a scan with the engine running (warm engine) and I now have the ESP warning because the battery lost all it's juice whilst cranking :frown new::frown new:
Any help with this greatly appreciated, as I'm sure like everyone else, I need my car working :blush:
Okay, fitted a new battery last Wednesday, and the car hasn't missed a beat since (touch wood).
Successfully erased the fault codes today, so fingers crossed it was all down to a failing battery (that a local tyre & exhaust place told me was fine).
Hi mate i think i had same issues as you long time ago. It was ignition barrel or coil (don't know the right word for it). Had it fixed when the car was in for service. It was replaced and it was about 40£.
Thanks for the response mate.
Sounds like you had the ignition switch replaced, as I think £40 is about the going rate for one.
Hopefully, fingers crossed a new battery has solved my issue.
