Hi guys.
We've got a 2009 A3 2.0 TDi 140 Cabriolet with the S-Tronic gearbox. Yesterday on moving the shift lever from reverse to drive, the car momentarily refused to change into drive. After this happened, a fault has presented itself where the car will crank over (and start) but cuts out almost immediately again. It refuses to start, essentially, and cuts out straight away.
Car is fine apart from this, well looked after, only 31k miles, NO warning lights on dash apart from an occasional orange DPF flash in the top third of the central DIS screen.
The log from the VCDS hookup is copied below - is anyone able to translate this into layman's English for us please? We need to figure out what needs changing and how straightforward it may/may not be - plus cost implications.
Thanks for your help.
________________________________________________
Wednesday,25,July,2012,20:05:12:33777
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 1K0
Scan: 01 02 03 08 09 15 16 17 19 25 26 42 44 46 52 56 62 72
VIN: TRUZZZ8P391004625 Mileage: 51490km/31994miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
26-Auto Roof -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 BR HW: 03L 906 022 BQ
Component: R4 2,0L EDC 0000AG 3067
Revision: 13H01--- Serial number: AUX7Z0H6FN104Y
Coding: 0000078
Shop #: WSC 01236 785 00200
VCID: 76E801C501DC1C9
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 051 HW: 02E 927 770 AJ
Component: GSG DSG AG6 431 1811
Revision: 04843012 Serial number: 00000806200366
Coding: 0000020
VCID: D0A4175D43F8929
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AE HW: 1K0 907 379 AE
Component: ESP MK60EC1 H35 0104
Revision: 00H35001
Coding: 13424012092200FEC81102E6901E0082B900
Shop #: WSC 01236 758 00200
VCID: 75EA06C9DCDA171
Address 08: Auto HVAC Labels: None
Part No: 8P0 820 047 B
Component: J255 Klima Man H07 0030
Shop #: WSC 00000 000 00000
VCID: 2F66F4A1BE066D1
Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 N HW: 8P0 907 279 N
Component: Bordnetz-SG H54 2801
Revision: 00H54000 Serial number: 00000008691572
Coding: 10202F01B0141080EF00001C0000000000084A0164010001002000000000
VCID: 4894BF3D3BA8DA9
Subsystem 1 - Part No: 8P2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H10 0040
Coding: 00056595
Shop #: WSC 01236
Address 15: Airbags Labels: 8P7-959-655.clb
Part No SW: 8P7 959 655 HW: 8P7 959 655
Component: SR Airbag 9.43 H01 0020
Revision: 93H01002 Serial number: 003BS000APB2
Coding: 0021330
VCID: 06087105713C0C9
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0011101
VCID: 4182A2191892EB1
Part No: XXXXXXXXXXX
Component: E0221 H02 0030
1 Fault Found:
00883 - Ignition Switch (D) Terminal S
012 - Electrical Fault in Circuit - Intermittent
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 982 C HW: 8P0 920 982 C
Component: KOMBIINSTR. VDO H15 0820
Revision: D0H15004 Serial number: 2246H004002739
Coding: 0002428
Shop #: WSC 00388 210 91840
VCID: 3972CAF97042B31
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533__Gateway H16 0202
Revision: H16 Serial number: 2700K086028333
Coding: ED807F260002029101
VCID: 356AC6C95C5A571
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H15004 Serial number: AUX7Z0H6FN104Y
Address 26: Auto Roof Labels: Redir Fail!
Part No: 8P7 959 255 A
Component: VSG AUDI A3 H14 0100
VCID: 438EA811028EF91
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P7 959 801 C HW: 8P7 959 801 C
Component: Tuer-SG H02 0020
Coding: 0000692
VCID: 4280AD151D94F09
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 233 2301
Revision: 00H15000
VCID: 2A50E5B585E4089
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 J
Component: KSG H11 0080
Coding: 1990202042386D0985254C9ED633
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Part No: 8P7 951 177
Component: DWA-Sensor H03 0030
1 Fault Found:
00849 - S-contact at Ignition/Starter Switch (D)
008 - Implausible Signal - Intermittent
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 8P7 959 802 C HW: 8P7 959 802 C
Coding: 0000692
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8P0 035 152 C HW: 8P0 035 152 C
Component: R Chorus2+ H19 0270
Revision: 00H19000 Serial number: AUZ1Z2H0523817
Coding: 0000221
VCID: 2B5EE0B18A1E111
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 8P7 959 811 A HW: 8P7 959 811 A
Component: Tuer-SG H01 0030
Coding: 0000144
Shop #: WSC 01236 785 1012552
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 8P7 959 812 A HW: 8P7 959 812 A
Coding: 0000144
End ---------------------------------------------------------------------
Address 16: DTCs cleared
Address 17: DTCs cleared
Address 19: DTCs cleared
Address 25: DTCs cleared
Address 26: DTCs cleared
Address 42: DTCs cleared
Address 44: DTCs cleared
Address 46: DTCs cleared
Address 52: DTCs cleared
Address 56: DTCs cleared
Address 62: DTCs cleared
Address 72: DTCs cleared
Chassis Type: 1K0
Coding: 0000078
Coding: 0000020
Revision: 00H35001
Coding: 00056595
Shop #: WSC 01236
Coding: 0021330
Coding: 0011101
1 Fault Found:
Coding: 0002428
Coding: 0000692
Revision: 00H15000
1 Fault Found:
Coding: 0000692
Coding: 0000221
Coding: 0000144
Coding: 0000144
