LED Rear Lights Coding Wiltshire
Welch25
Salisbury
Anybody help me sort my lights out, Have fitted the LED Rear lights with the wiring adapters, just need them coding, does this have to be main dealer ?
I have error on brake,fog,reverse lights, side lights indicators ok
Check the vcds Map for someone close to you and message them. Can be done via vcds.
Have looked at the maps, closest ones don't not seem to be active in the last 6-8months,
I can do it however I'm in Dartford Kent.
Do you have the list of coding changes? as its a very specific set of codes that can cause issues if not entered correctly.
No I don't have the codes, have found someone near to me with a Vcds just need the codes now.
