RNS
Deanjames
Was wondering if anyone can help. My Navigation CD has gone walkies, I am due a couple of long drives soon so need to get myself a replacement ASAP.
I have the below unit, is it just a case of getting the new maps or am i going to have to do a firmware update, where is the best place to purchase these form ?
SW: X----
HW: H80
MAP:
There is a guy in the sales section selling maps.
That unit has been hacked for a pin number change if its got the X in the firmware.
Whats does this mean ?
Will i still be able to update / use maps if i purchase a CD?
Newer maps should work, but sometimes when hacked it causes issues with newer discs, I've had a fair bit of experience with this, so I'm jst warning you, usually I reflash the unit firmwares so it shows up correctly, then there are no issues with any dvd's.
How easy is it to re flash the firmware ? Assume its just a disk ?
What kind of issues can this cause ? Could i potentially brick the unit ?
You'll need older dvd firmware to download then upgrade to 0650, plus vcds to put into downgrade mode, the reason why I goto older version 1st is to make it as clean a flash as possible.
903
NHN
9
31
J0N
339
