Knarry
- Joined
- Jan 28, 2015
- Messages
- 15
- Reaction score
- 3
- Points
- 3
- Age
- 37
Hey guys,
I tried my best to not post a thread about the oil light but I have exhausted the info I could find on the net and hoping someone here can now point me in a direction.
I purchased a 1999 1.8t quattro A3 about a month ago and it came with that dreaded flashing oil light on the dash, Its the big oil can symbol in the center accompanied by 3 beeps (the whole display is red) The beeping only comes on when the car is up to temp and i have been driving for a while so i didn't think it would be a wiring fault.
I ran the car on vag-com and got the fault 00562 for oil level/temp sensor. I started by running a flush through the engine and replacing the oil and filter and fitting a new oil level/temp sensor. This did not cure the problem, so i ordered and fitted a new oil pressure sensor which also did not cure the fault. After that I decided I would take my sump off and check it out inside to see if the pick up was blocked up. the sump itself is relatively new, the previous owner caught it on a rock apparently and had it all replaced so the inside was sludge free and the pick up wasn't too bad either. i changed the oil pump while i was in there for good measure and stuck in some new oil this time going for 5w40. Took the car for a drive but after a little while the damn beeps returned... Any advice would be grand as I'm out of ideas
Thanks in advance
Thanks in advance
