Coilovers for the 8V
If anyones still after some, may be selling my b16's !
Reactions: PacMan88
Ah i dont know what to do, id like to keep them on just thinking when i come to sell it itll be hard in cyprus trying to sell a modded car
Anyone that knows anything about cars wouldn't consider bilsteins as a mod, it's a quality upgrade.
You can set the ride height to stock and nobody would even know anyway.
Keep changing my mind every 5 mins but one things for sure, its leaving southampton port on the 12th!
Lucky, I wish I could move to a hot sunny country and make a living while still owning the s3.
I'm stuck in the big smoke :-(
keep the Bilsteins and raise them up if have to, like others have said - why keep the standard ones !
Guess there are worse things in life haha... could i really split this up :neutral:
img_3434-jpg.71843
Reactions: Fiddie
sorry couldn't resist - some of us don't have to move. :sunglasses:
IMG 7594
Reactions: S. and veeeight
Why why why are the jobs in cold wet country's!
Any ways back in topic.... Keep your bilsteins
If i keep them may aswell keep the rest of the stuff on, then is it worth selling standard stuff
Cars going on a Ferry where nothing can be left in the car. Good chance ill end up bring it back to the uk but who knows
Anyone wanting suspension items fitted and alignment in the South Coast area should check this out >
https://www.facebook.com/naduk.co.uk
Going here on Thursday to have coilovers fitted and full alignment completed.
Got the H&R coilovers installed and aligned today at NAD UK (Littlehampton, W. Sussex) . Top bloke, suspension set ups are his speciality.
The "bounce" has gone and the car generally feels more compliant.
I have attached the geo pre coilover fitment when the car was on H&R lowering springs and after.
The setup is a hybrid between the S3 and Golf R, and so far I like it.
Untitled
Reactions: Lhasa2008, PanamaS3, Fiddie and 3 others
Here are the S3 and Golf R standard geo settings. Note the Golf R has more negative camber.
S3 - Standard alignment settings (from workshop manual)
Sports running gear S3 and sports running gear S3 with Audi magnetic ride G06, G07, G26, G27, G46, G47 + 2UC
Front Axle
Total toe 10′ ± 10′
Toe setting at each wheel 5′ ± 5′
Camber (in straight-ahead position) -47′ ± 30′
Maximum permissible difference between left and right max. 30′
Toe-out on turns with 20° steering angle 1° 40′ ± 20′
Caster 7° 49′ ± 30′
Maximum steering angle at inner wheel 39°57′
Rear Axle
Total toe 25′ ± 10′
Toe setting at each wheel 12.5′ ± 5′
Camber -1° 20′ ± 30′
Maximum permissible deviation from direction of travel max. 12′
Golf R - Standard alignment settings (from workshop manual)
Golf R 18" G04 +2UK + 1N7/ G04 + 2UL + 1N7
Front Axle
Total toe (unladen) 10′ ± 10′
Camber (in straight- ahead position) -44′ ± 30′
Maximum permissible difference between sides max. 30'
Toe-out on turns with 20° steering angle 1° 38′ ± 20′
Caster 7° 45′ ± 30′
Ride height 363 ± 10 mm
Rear Axle
Total track (at prescribed camber) 16′ ± 10′
Camber -1° 45′ ± 30
Max. permissible deviation from direction of travel max. 20'
Ride height 365 ± 10 mm
Front Axle
Total toe 10′ ± 10′
Caster 7° 49′ ± 30′
Rear Axle
Total toe 25′ ± 10′
Front Axle
Caster 7° 45′ ± 30′
Rear Axle
Camber -1° 45′ ± 30
I run the golf r settings at their most extreme.
Made a massive difference to turn in and the high speed handling on the ring was so much better with less understeer enabling me to put more power down mid corner.... Also more tail happy :)
Reactions: veeeight
B14's on with golf R geo setup and its made a massive improvement in handling, turn in as said is greatly improved. Went with a one finger gap at the front and two at the rear, I prefer my cars nose down slightly, just looks more aggressive.
Reactions: Steph67
Iv ordered the kW v3 the just to mix things up
So had some B14 Fitted today ...OMG what a difference worried about being to hard I would say there softer than stock & no crashines.verry happy :)
Reactions: Lhasa2008 and Steph67
They do make a massive transformation, a quality upgrade indeed!! :smiley::smiley:
PM me! You could save me a expensive trip to Awesome next month
Maybe a silly question but if you brought a set of say B14's or B16's would you be able to swap them onto a RS3? that will be my next car after my PCP end's
Theoretically yes, as its the same chassis, but there could be some variations since that is the more performance minded vehicle. Keep in mind, if they do work, the wagon is a little heavier so the spring rates could be different.
Would you recommend them? Have they reduced the crashiness of the stock suspension?
So, I got some b14s, getting them fitted tomorrow :) have people cut the bump stops in half? I read the Americans have been doing that? What height have people recommended?
Left mine stock for my b16's. I'm at the highest setting currently and haven't ever felt they got close to bottoming out. But is duo whatever the directions suggest.
Sent from my SM-N910V using Tapatalk
So, is there a chance the coilovers can be fitted incorrectly? Because they seem pretty bouncy and harsh to me.
Think the only way it could be installed incorrectly is the top mounts which wouldn't affect the bouncyness. The bump stops won't do that either.
Mine aren't bouncy, pretty planted but gets bouncy on rough pavement.
