Jakub
- Joined
- Nov 3, 2013
- Messages
- 37
- Reaction score
- 24
- Points
- 8
- Location
- Mlada Boleslav (home of Skoda), CZ
Hi guys,
At first I would like to apologize for my English, but I'll try hard to clearly explain what to do.
Before
After
The whole thing is that you just cut off small part of strut.
Note: Don't worry about sway bar links, in my case there were no problem after the mod.
The whole thing took me about 3 hours of work.
Good luck, hope it helped!
Before
After
- Problem
Tools needed:
- all tools needed to remove front struts (link in step 1.)
- Calliper
- Hacksaw
- Rasper
- Sandpapers (400 - 1000)
- Spray paint
How to:
- 1. First you need to remove your front struts. (nice how-to is here: http://forums.vwvortex.com/showthread.php?4330188-Koni-Coilover-Install-DIY note: for many adjustable coilovers you don't have to remove driveshaft, because the struts are much shorter) On the second picture, you can see how much of excessive material is on the strut.
- 2. Now measure and mark where you want to cut the strut. In my case I shortened it by 8 mm. The engineer from Skoda said, that in this case (AP coils) 12 mm off should be still safe. Just NOT to cut into the weld!!! You also have to shorten the "thing" on the second picture. In my 5 mm off did well.
3. Now cut it off. I did it with a hacksaw. Do NOT use electric angle grinder, because it generates a lot of heat during cutting, which could damage the strut and oil in it.
- 4. When the part is cut off, grind down the edges. Use rasper and sandpapers (400 - 1000). Do NOT use electric grinder, because of generated heat.
- 5. Paint all grinded to prevent oxidation and rusting.
- 6. Fit coils back onto the car and enjoy the look!
