RS4 minimum wheel size
grainqey
Rotherham
Hello,
Sorry for intruding on the A4 section - as I drive an A3...
Whats the minimum wheel size on the RS4 though as it has 380mm discs does it not?
I've seen a winter wheel size of 18" but is this true - I thought it was 19" 's only?
Alex
P.S upgrading the A3 to 360mm discs under Avus wheels
Someone in here running RS4 brakes might be able to help - but you might get a quicker answer in the RS4 specific section...... this section is for us mere mortals who don't have RS's :)
RS4 B7 use 365mm discs up front, they can be fitted with 18" wheels but only if its the right offset.
Thanks for the replies and sorry for posting in the Non RS specific forum :keule:
I thought they ran bigger discs than 365 tbh
Thanks for that Docurley - I may end up swapping to 19's but I spent quite a while trying to get my 18" avus' never mind trying to find some 19's
If you are running or going to try and run RS4 brakes be prepared to go to the wheel company for a test fir as not all wheels clear the RS4 Callipers.
Thanks for that docurley, I'm using 4 pot brembos similar to the TTRS/RS3 so shouldn't be a problem with 360mm discs :)
...wheel balancing weights may be an issue but unsure at the moment :suspicion:
561
565
12
614
45
3K
23
968
