First VCDS scan
S3DUST
Just add boost :D
Hi All,
Just thought i would share my first scan. A few faults came up and one im worried about ! comments welcome...
Car is an 09 S3 Revo stage 1
You will see it has flagged low fuel pressure once and over 1000 miles ago. I took her out for a spirited drive after clearing for around 30 miles and the fault didn't reappear. I did run it very low on fuel at the begining of the month (vapor's) as i was determined to get to the shell garage for vmax. Could this of caused the problem or just a glitch or sign of a worn HPFP ? I have never had an Engine light on.
Also it says Nav and radio Ariel short to ground. Is this a known issue and is there a fix ? this fault reappeared straight after being cleared... The Nav is very slow to initialize, it takes around 2 minutes to lock on, is this normal ?
Log Below:
Address 01: Engine (CDL) Labels: 06F-907-115-CDL.clb
Part No SW: 8P0 907 115 AB HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0010
Revision: 5BH16--- Serial number: AUX7Z0H7FN70F4
Coding: 0103000C180F0160
Shop #: WSC 14391 154 427783
VCID: 72EB3C436D5AFA8E927-8027
1 Fault Found:
012555 - Low Pressure Fuel regulation
P310B - 002 - Fuel Pressure Outside Specification - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 114439 km
Time Indication: 0
Date: 2014.11.02
Time: 19:56:34
Freeze Frame:
RPM: 6777 /min
Load: 85.8 %
Speed: 131.0 km/h
Temperature: 90.0°C
Temperature: 37.0°C
Absolute Pres.: 990.0 mbar
Voltage: 13.208 V
Readiness: 0000 0000
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8P0 035 193 G HW: 8P0 035 193 G
Component: RNS-E PU EU H07 0200
Revision: 0000013S Serial number: AUZBZ7MD216098
Coding: 0209755
Shop #: WSC 13392 000 10485
VCID: 3467FA5B57CEB4BE40B-8061
1 Fault Found:
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 5
Fault Frequency: 1
Reset counter: 193
Mileage: 116116 km
Time Indication: 0
Date: 2014.11.22
Time: 14:23:07
Freeze Frame:
Mileage: 116110 km
Count: 2211
Clock: 14:22
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0209755
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 193
Mileage: 116116 km
Time Indication: 0
Date: 2014.11.22
Time: 14:23:07
Freeze Frame:
Mileage: 116110 km
Count: 2211
Clock: 14:22
Thanks for looking :)
Send me the rns e and I'll test it for a few month's and get back to you:D
Reactions: S3DUST
LOL :) I do love it :) just a little slow to initialize but once it has it never drops signal. Also no issue with radio reception ?
Don't worry about the signal, every single audi will come up with the same fault even if just out of factory. God knows why they do but they do, it's laughable!
Reactions: S3DUST
Any thoughts on the low fuel pressure?
I'd check your cam follower is worn through first.
Then what fuel setting are you running on Revo stage 1? As it's only picked the code up at 6700 rpm.
I have no errors in my rnse.
Has the Rnse been retrofitted do you know? They can have antenna issues showing up on vcds due to the different radio ariel set up but still work ok
I'm going to change the pump and follower in the new year for stage 2+ :)
I'm not sure if it's been retrofitted? It's got the Bose speakers.
I suspect you may be right though as if they have been fitted after don't you mount the nav ariel somewhere in the dash? Could this explain the slow initialization?
Yes if the hockey puck is used normally it gets tucked under the dash. Do you have a sharkfin or Bluetooth?
NO idea on the Revo Fuel settings, i don't have the SPS... Its odd as the car has done around 12000 miles on stage 1 and from the log it has only happened once if i have interpreted it correctly ? :s
I have Sharkfin Ariel and bluetooth for the handsfree. Is that what you meant ?
Rich
Rich
Yeah that's it, if you have Bluetooth then you will have a sharkfin as it does either or both dependant on spec.
If you pull the rnse from the dash, you'll know for sure.
Reactions: S3DUST
With bluetooth the module is in a small plastic "briefcase" under the passenger seat, under the carpet. If you slid the seat right back and lifted the access panel for the seat wiring and look towards the handbrake under the seat, you should be able to see if there's a plastic box or a piece of polystyrene where it would be.
Reactions: S3DUST
763
fad
