Liquidfusion-S3
I fall to peer pressure!
Does anyone know how to reduce the parking sensors distance from 30cm to anything lower like 10cm?
It holds a steady beep once you get close to an object within 30cm.
Reason why is because the A4 is a long car, parking in supermarkets can be a bit troublesome when you're not in enough. I use the parking sensors but am always something like 30cm away from the wall.
I'd like it to hold a steady beep once I'm within 10cm of the wall.
I have access to VCDS so I assume it would be done there somewhere?
