SmithyAG
I'm assuming that the injector duty cycle is maxed out at around 230bhp then? I think I need to do some VCDS logging and see how close to max mine are.
What CC are stock injectors? Can they not be increased by using a stronger fuel pressure regulator?
As far as I am aware it is the nozzles of the injectors that limit you to 230bhp, as they just can't flow any more fuel than that.
The uprated ones usually come with a choice of nozzle flow. You run into problems if you go too big, as it becomes difficult to get the car to idle smoothly, as there always seems to be too much fuel.
The uprated injectors are actually stock injector bodies with new nozzles, hence why you need to hand a set back to whoever you buy them off (so they can refurb yours with new nozzles and sell them on).
