More vagcom VCDS help
dandav1985
Active Member
39
Newcastle upon Tyne
Hello,
while driving round yesterday I noticed the auto wipers are not as sensitive as I'd like them to be, is there anyway via VCDS that I could make these more sensitive, I've tried the dial on the wiper stalk but no joy.
Also if I hold the open bottom on the key fob down all the windows go down, but when I hold the closed only the front windows go up and leaving the rear windows down. Had a look on VCDS and can not seem to find anything, will I need to adapt? Someone has told me it may because my car has folding mirrors but I find this hard to believe.
Car is in my signature.
cheers once again Dan
This is normally the case when the windscreen hasn't been replaced with a genuine Audi windscreen and the sensor and gel pad aren't making correct contact or something along those lines. Do you know if the windscreen has been replaced?
The rear windows need re-training - hold the up switch for around 10-15 seconds after they stop rising to reset them to their upper limits.
The up switch being the front window switch for the rears both sides or the rear individual switches in rear doors or the lock button on the key fob.
Help would be appreciated.
Cheers Dan
Well, tried opening rear windows from the switches in the front and then closing them with same switches, then holding the switches for 15 seconds turned car off, then lock car with key fob, open windows all works fine . Then holding the lock bottom on key fod front windows only go up again so still not working. Also noticed that the one touch close from the window switches only work on the front and not the rear.
Many more suggestions. Seems like I've enherited someone else's problems .....:(
Cheers once again Dan.
I took the rear view mirror off on mine and played about with that gel pad and gave it all a clean and it sorted my wipers and auto headlights, the wipers was useless and the headlights use or stay on in the day time prior to this .
Cheers I'll try it see what happens, it has had the windscreen changed like not a genuine audi one either, so if it dose not work think I'll invest in a real audi one....:)
Still no joy with the rear window though :(
Cheers Dan
Cheers Dan
No need to replace screen, they may have not put the gel pad in there, it's only a couple of quid from audi .
If you can get a good close up pic on here of the outside if your windscreen I should be able to tell whether the gel pad has been put back to save you dismantling the mirror .
Just need a close up of the top of the windscreen where the rear view mirror attaches.
Reactions: dandav1985
ImageUploadedByTapatalk1392541334816710
If the gel pad is missing or fitted incorrectly it will look clear like the above pic.
If it has had the gel pad fitted and correctly it will look all black from a distance as shown in pic below.
ImageUploadedByTapatalk1392541402733290
Hope this helps
Hello,
Here's a picture of the window been really busy today, so only just got the chance to get on now.....
Looks to be missing to me, so I'm going to buy one hopefully tomorrow from TPS would you have a part number.
Cheers for your help.
Rear windows are still confusing me.....:(
Cheers Dan
Hello,
Cheers Dan
It does look like it's missing , if it looks clear when standing back from the vehicle then I'd say its defo missing.
Sorry don't have part number but as soon as you ask for the gel pad at the dealership they should know, think it's only around 10 quid.
Does your auto lights stay on in the day ? Any issues with them?
Took mirror off today sea if the gel was in the sensor and found it was not so, bought one from TPS for £ 13 wow........
Now with the new one fitted
Just need it to rain now......even though we've loads of rain the last couple of weeks lol.
Cheers for the help much appreciated.
Cheers Dan
If they dont go up with one touch they need training again, repeat the steps in post #4
Am I doing something wrong with this, I've done the steps in post 4 about 10 times and still now joy........:(
Can there be a fault with the door controllers........:banghead:
Cheers Dan
Do you rear windows operate with one-touch up and one-touch down?
From which switches?
Cheers Dan
No problem at all, Glad it sorted it mate ,prob the best cheapest fix you will get .
It will work fine now, get the watering can out n test it . Ha
Hello,
No the rear windows don't work one touch from any of the switches. The front windows are working perfect.
Cheers Dan
I may be wrong, but for comfort/convenience windows to work from the fob, you need one-touch windows.
So you need to fix your one-touch (if fitted to the rear) first.
Really happy mate thanks, I've got the garden hose pipe out works spot on.....:icon_thumright:
Try this reset method:
Ignition ON
Press and hold window switch down, when window reaches bottom, hold button down for a further 5 seconds
Pull and hold window switch up, when window reaches top, keep pulling button for a further 5 seconds
Test one touch function
Ignition OFF
Ignition ON
Ignition OFF
Hello,
just tried this now. Still no joy, no soft touch on the rears still and still not closing with the key.
Really don't understand what is going on....I've just noticed that the rear drivers window switch is faulty! Maybe this could be the problem
Almost certainly. Any VCDS fault codes?
You must get one touch working first, before convenience close will work from the fob.
Pretty certain that it should bring up a fault code , mine brings up a fault code for it, the one touch plays up sometimes, only on my drivers door , the rest are fine but it for sure shows the fault on VCDS .
[QUOT E=dandav1985;2087573]Really happy mate thanks, I've got the garden hose pipe out works spot on.....:icon_thumright:[/QUOTE]
No problem at all.
On to the next fault eh! Ha
Hello,
Just done a scan with VCDS now........this is what it is saying.
Monday,17,February,2014,20:16:29:13746
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
Dealer/Shop Name: Daniel Miller
Workshop Code: 123 12345 012345
VIN: WAUZZZ8P700000000 License Plate: S3
Mileage: 68660km-42663mi Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 25 37 42 44 46 52 55 56 57
62 72 77
VIN: WAUZZZ8P700000000 Mileage: 68660km/42663miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
57-TV Tuner -- Status: Malfunction 1010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine (CDL) Labels: 06F-907-115-CDL.clb
Part No SW: 8P0 907 115 AP HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0010
Revision: 5BH16--- Serial number: AUX7Z0INFNA10J
Coding: 0103000C1C0F0160
Shop #: WSC 00772 129 00000
VCID: 80096769D336311E143-80D5
No fault code found.
Readiness: 0110 0100
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 013 N HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2601
Revision: 05351113 Serial number: 00001103120520
Coding: 0000020
Shop #: WSC 06314 000 00000
VCID: 1C31B319DF9E75FE68B-8049
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AJ HW: 1K0 907 379 AJ
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 16428012092B00FD680B01EA901B0081390000
Shop #: WSC 12345 123 12345
VCID: 7AFD9581F5EAEBCEDA7-802F
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 BL HW: 8P0 820 043 BL
Component: KlimavollautomatH09 0140
Revision: 000297 Serial number: 8P0820043BL
Shop #: WSC 00000 000 00000
VCID: 77FB8CB506F8F6A6A59-8022
Address 09: Cent. Elect. (J519) Labels: 8P0-907-063.clb
Part No SW: 8P0 907 063 A HW: 8P0 907 063 A
Component: BCM PQ35 M 105 0575
Revision: 00105 AJ
Coding: 0E000A3FE827F0C0207241E00100895C477E2BAA307DD929E40000840040
VCID: 326D7DA16D1AD38E527-8067
Subsystem 1 - Part No SW: 8P2 955 119 F HW: 8P2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H11 0050
Coding: 00DD13
Subsystem 2 - Part No SW: 8K0 910 557 HW: 8K0 955 559 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSEN H04 0003
Coding: 024C2D
Subsystem 3 - Part No: 8P0 951 177
Component: Innenraumuebe H04 0020
Subsystem 4 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 5 - Part No: 1K0 907 719 C
Component: Neigungssenso 005 0003
Address 10: Park/Steer Assist (J446) Labels: 8P0-919-475-7X1.clb
Part No SW: 8P0 919 475 G HW: 8P0 919 475
Component: PARKHILFE 4K H06 0120
Revision: 11001001 Serial number: 93640931709286
Coding: 000103
VCID: 428D2D61DDBA630EC27-8017
Address 15: Airbags (J234) Labels: 8P0-959-655-10.clb
Part No SW: 8P0 959 655 P HW: 8P0 959 655 P
Component: Airbag AU1042 H06 0160
Revision: -------- Serial number: 003FB00470HE
Coding: 30314238303830303037554A305238503053
ASAM Dataset: EV_Airba10AURB4 001001
ROD: EV_Airba10AURB4.rod
VCID: 4FAB145516E89E665D9-801A
Crash sensor for side airbag; driver side:
Serial number: 3572DRB40000D920EAA1
Crash sensor for side airbag; passenger side:
Serial number: 3582DRB40000D91CAB22
Crash sensor for side airbag; rear driver side:
Serial number: 35128RB4000051F70159
Crash sensor for side airbag; rear passenger side:
Serial number: 35228RB4000051F6035B
Crash sensor for front airbag; driver side:
Serial number: 35547RB400006213589E
Crash sensor for front airbag; passenger side:
Serial number: 35647RB4000062135F7K
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
Component: J0527 H37 0070
Coding: 0014142
VCID: 4685317131925F2EEEF-8013
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H06 0030
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 982 K HW: 8P0 920 982 K
Component: KOMBIINSTR. VDO H03 0990
Revision: D0H03004 Serial number: 224NI004000958
Coding: 0001418
VCID: 418F226D18BC7816DBD-8014
Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H16 0231
Revision: H16 Serial number: 4320K09B09063D
Coding: EDA37F06C00602003103
VCID: 69DFDACD404C505623D-803C
2 Faults Found:
01044 - Control Module Incorrectly Coded
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 1
Fault Frequency: 3
Reset counter: 99
Mileage: 68289 km
Time Indication: 0
00467 - TV Tuner (R78)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 15
Reset counter: 112
Mileage: 68322 km
Time Indication: 0
Address 22: AWD Labels: Redir Fail!
Part No SW: 0BR 907 554 B HW: 0BR 907 554 B
Component: Haldex 4Motion 3017
Coding: 0000005
VCID: 44812B7907AE6D3EF0B-8011
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H03004 Serial number: AUX7Z0INFNA10J
Shop #: WSC 00137 211 56823
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8P0 035 193 G HW: 8P0 035 193 G
Component: RNS-E PU EU H06 0210
Revision: 0000012S Serial number: AUZBZ7LD201789
Coding: 0209725
VCID: 34617BB9570EDDBE40B-8061
2 Faults Found:
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 56
Mileage: 68289 km
Time Indication: 0
Date: 2014.02.13
Time: 16:01:26
03157 - Functionality limited due to Communications Disruption
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 56
Mileage: 68289 km
Time Indication: 0
Date: 2014.02.13
Time: 16:01:29
Freeze Frame:
Bin. Bits: 00000000 00000000
Bin. Bits: 10000000 00000000
Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX3.lbl
Part No SW: 8P0 959 801 M HW: 8P0 959 801 M
Component: Tuer-SG H04 0100
Coding: 0004788
VCID: 4587367D0C945436E75-8010
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 234 3201
Revision: 00H20000
Shop #: WSC 02069 000 90108
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 8P0 959 802 M HW: 8P0 959 802 M
Coding: 0004788
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P3 907 357
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000013
VCID: FAFD1581B5EA6BCE5A7-80AF
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0209725
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 56
Mileage: 68289 km
Time Indication: 0
Date: 2014.02.13
Time: 16:01:26
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 56
Mileage: 68289 km
Time Indication: 0
Date: 2014.02.13
Time: 16:01:29
Freeze Frame:
Address 57: TV Tuner
Cannot be reached
Address 62: Door, Rear Left Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 F HW: 8P4 959 802 F
Component: Tuer-SG H04 0050
Coding: 0000144
Shop #: WSC 38100 001 1012557
VCID: 4383286502A06A06C91-8016
Address 72: Door, Rear Right Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 F HW: 8P4 959 801 F
Coding: 0000144
Shop #: WSC 06314 000 1012544
VCID: 428D2D611DBA630EC27-8017
1 Fault Found:
00938 - Switch for Electric Window; Rear Right (E54)
008 - Implausible Signal - Intermittent
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 AA HW: 8P0 862 335 S
Component: FSE_256x BT H38 0600
Revision: 00000000 Serial number: 00000005143603
Coding: 0011422
VCID: 75E786BD1CF484B6B75-8020
End ---------------------------------------------------------------------
Think it is strange how, the drivers side rear window affects the passenger one.....
Cheers Dan
Cheers Dan
Hello lads,
I'm still getting the problem with the one touch on the rear windows, I've replaced the switch and tried resetting the both rear windows.
Still no joy.....this car is really begining to pee me off now.
Any help would be great.
Cheers Dan
Anyone have any more suggestion, Planning on taking to audi but think they'll just try and rob me to be fair............:(
Cheers Dan
Cheers Dan
remove the battery for an hour or so , some times after messing with the coding it locks the system out.
You've got incorrect coding on the stereo/Nav unit for a start (2 errors).
Do you have full VCDS to be able to go and check the long coding settings within the convenience features? If not I suggest you find someone local from the VCDS map section that can help you.
Hello,
Yes I have full VCDS Ross tech hex can and the coding on the RNSE is correct now.......it was due to someone fitting the tv head rest to the car the head unit is sorted........:)
What should the coding be for the rear windows.
Cheers Dan
Heres a new scan which i just did, Can some one tell me if my coding is correct for the rear door controllers.
Saturday,03,May,2014,19:38:40:13746
VCDS Version: 14.5.0.0 (x64)
Data version: 20140501
VIN: WAUZZZ8P7AA093062 License Plate: S3 NEW
Mileage: 72620km-45123mi Repair Order:
Scan: 01 02 03 08 09 10 15 16 17 19 22 25 37 42 44 46 52 55 56 62
65 72 77
VIN: WAUZZZ8P7AA093062 Mileage: 72620km-45123miles
37-Navigation -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
65-Tire Pressure -- Status: Cannot be reached 1100
72-Door, Rear Right -- Status: OK 0000
VCID: 0009E7695336B13BA7-8055
Address 02: Auto Trans Labels: 02E-927-770.lbl
Coding: 0000020
VCID: 1C31B319DF9E75DB5B-8049
Revision: 00H30001
Coding: 16428012092B00FD680B01EA901B00813D0000
VCID: 7AFD9581F5EAEBEBE9-802F
VCID: 77FB8CB506F8F68396-8022
Revision: 00105 AJ
Coding: 0E000A3FE827F0C0207241E00100895C457E2BAA307DD969E40040840040
VCID: 326D7DA16D1AD3AB61-8067
Coding: 00DD13
Coding: 024C2D
Coding: 000103
VCID: 428D2D61DDBA632BF1-8017
VCID: 4FAB145516E89E436E-801A
Coding: 0014142
VCID: 4685317131925F0BDD-8013
Coding: 0001418
VCID: 418F226D18BC7833E8-8014
Coding: EDA37F07400602003103
VCID: 69DFDACD404C507310-803C
1 Fault Found:
01325 - Control Module for Tire Pressure Monitoring (J502)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 4
Mileage: 72621 km
Time Indication: 0
Coding: 0000005
VCID: 44812B7907AE6D1BC3-8011
Component: RNS-E PU EU H06 0220
Coding: 0200757
VCID: 34617BB9570EDD9B73-8061
Coding: 0004788
VCID: 4587367D0C945413D4-8010
Revision: 00H20000
Coding: 0004788
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Coding: 0000013
VCID: 7AFD958135EAEBEBE9-802F
Coding: 0200757
Coding: 0000144
VCID: 4383286502A06A23FA-8016
Address 65: Tire Pressure
Cannot be reached
Coding: 0000144
VCID: 428D2D611DBA632BF1-8017
Coding: 0011422
VCID: 75E786BD1CF4849384-8020
Cheers Dan
You'd maybe get a better response posting this in the VCDS forum, mate
