Hmmm...unfortunately, my VCDS doesn't display what the Bytes and Bits refer to in my RLFS module
Yes, 00006C sounds very familiar!
* I've also tried 06885D and 07E8DD but they didn't work either.
Have been doing some further testing today with no luck. Rain closing works for windows only. So far people have been using the codes found on VW forums. Although they work If you have an Audi you should really revert them.
Here is a break down:
Byte 0 = The Sum of all activated features and adjustments
- Bit 0 = Highway Light Function
- Bit 1 = Rain Light Function
- Bit 2 = Rain Closing
- Bits 3 to 5 = Light Activation Threshold earlier (+20% to +80%)
So 07 = Bits 0, 1 and 2 are Active.
Byte's 1 and 2 (combined) = Vehicle Model
XX9597 = A Seat Alhambra (whatever the hell that is!)
XX805D = A Skoda Octavia
XXA8DD = A VW Golf (mk7)
From all the VCDS scans and data I have been sent I have found that
ALL A/S3 8V Models and Variants are coded as 00006C from the factory. I have tested using 07006C and Rain closing works, all be it without including the sunroof. I would suggest reverting to this.
The way I see it the sunroof issue is one of three things:
1) The correct Make and Model codes need to be entered in to Byte 1 and 2, but from what I have seen so far all Audi A/S 3 models and variants with a RLFS are factory coded as 00006C. Maybe there is an additional code for models with a sunroof...
2) If XX-006C is correct then maybe there is a "bit" which denotes the Sunroof. (will not know this until RossTech update the label file).
3) Need to find a way to make the Rain Closing Menu Pop in the MMI. (Am betting there is a check box in there to include sunroof as Audi have also split out the options [front windows, rear windows, Sunroof] in all other Lock / comfort related menus).
With regards to number 3, I just tried a "Global" factory reset on all the cars systems as this seemed to work on Golf mk7's. All settings (Radio, Nav etc) have reverted back to factory but the "CAR" settings (Red Menu: Drive Select, Driver Assist, Locking etc) have been retained and on further digging around in fact there is no option to reset "CAR". I even looked in the Engineering menu but there is again no option
Would anyone know how to perform a factory reset on the Audi "CAR" system?
