S3 injectors
chrisa4quat
Where can I get hold of some? Are these the best for the 2.0t upgrade?
This is the part number you need
06F 906 036 F
you can search ebay and google using that number.. i think you can get them cheaper off ebay.de
06F 906 036 F
I'm guessing another remap will be in order after fitting?
What if I fitted just Injectors no ko4?
Looking for 300bhp ish. Already have hpfp & decat
No gains by sounds of it mate !?! Waste of time snd money unless you get ko4
Ko4 from 1.8t???
The K03 unit on the TFSi will out flow the k04 used on the early 1.8t.
The flow rate of the current injectors are good enough for 300bhp if your going k04 then you'll need the S3 injectors, if your going for a bigger frame turbo then use RS4 injectors.
I am after about 300 for now. Need to et a dyno. So far de cat, induction kit, hpfp internals, exhaust and a map. Just feels slow still. Friends say it aint but to me it is
Sounda like your just used to the power mate ! With your current mods you should be around 280ish so i very much doubt iys slow lol
Id reccomend the K04 upgrade, just do the Injectors and get a stock decent K04 from a 2.0tfsi TTS or S3. You only really need one custom pipe to make it work and mine mapped to just under 340ps and 470nm. Check out Solaris and his K04 Hybrid thread on both his and my builds. If you shop around you can get a K04 for about £600?
933
914
548
467
815
