Part number for a Radiator and air con fan
m1nhx
Hi guys,
My 2004 2.5tdi advant (163hp) auto starting leaking coolant sometime ago, I've had it pressure tested and seems like I need a new rad also the air con needs replacing, I've been quoted £226 for the rads but have found a cheaper one on the bay, a genuine rad with a oem part number of 8E0121251P I tried searching this forum but unable to find any result and of course the dealers don't help. Does anyone know which part number I need so I don't order the wrong part?
Many Thanks
Minh.
that one is for vehicles with tiptronic engine codes BDV and AMM but it is the same size as all the rads
edit its not the same size as all the rads there is a few with a smaller core
what engine code is yours?
Not sure can't see anything on the engine bay - may need to remove the engine cover to see the engine tag code but a newbie at these things so not really confident on how to remove. it's a FWD 2004 2.5 tdi sport model
It should be on your V5 or on the data sticker in the spare wheel well
8E0121251J is the part number you want and with oil cooler its 8E0121251Q both are the same dimensions 632x414x34mm
J says manual gearbox so i'm guessing Q will be for auto hence the oil cooler
Wow that was a quick reponse - many thanks stu. now I just have to hunt for something cheaper than the price at the dealers.
no worries
is yours the manual or the auto?
it's an auto - heard so many problems with auto's but mine seems to be running smooth still - touch wood.
I think you may need the part number with Q then with an oil cooler try a audi dealer to see if they will confirm it some are ok my local one wont do anything though!
670
693
10
4K
