Audi a3 help
Sounds like a slave cylinder fault. Mine was leaking and I had the same symptoms. New slave cylinder, clutch, dual mass flywheel, master cylinder and £1000 later I had my car back on the road.
Well hope it's not that serious :(
Nope, I think you'll just need the slave cylinder - but get it bled first!!!!
You have the new clutch already....:rolleyes:
Phew :) how much are they and the diesel flap thing where is cheap place for that please
Audi Rear Wiper Motor with Rear Wash WipePart Number: 8L0 955 711 A - 8L0955711 A - 8L0955711A
This is a genuine Audi Rear Wiper Motor, It was taken from a 2001 Audi A3 1.8T with the 4 pin plug
Please check that this item will fit your carBEFORE bidding​
All parts may fit other cars/engines, check with your local dealer!
Any questions please askPlease see our other auctions
Will this work
Doubt it, it's from an 8l and yours is an 8p. Someone will correct me if I'm wrong!
Hi went to garage today been told its a problem with the hydrolic of the clutch bearing ??
The bearing is a concentric slave cylinder design.. Is there any irregular noises? Try putting your foot down on the top inch or so of the pedal? Any irregular noises then? Any change in pitch when the clutch pedal is depressed fully etc?
Entirely possible it needed a clutch and dual mass flywheel but they've whacked a clutch in and decided to sell it as is.
Master cylinder is a fairly easy job, some people remove the pedal box etc but it's not always necessary - slave cylinder if required is normally inside the gearbox bellhousing, going over the input shaft. The gearbox would need to be removed to replace this part.
12
812
591
638
431
576
NHN
