sideways steve
Further to my post about a leaking car.....
I took the plastic scuttle panel out last night (beneath the windscreen) to check the drain holes were not clogged up with leafs etc.
They were clear, however i noticed that the pollen filter was soaking wet and that the water has been coming in though there. It seems to be running down the window and onto the filter which then obviously allows it to come down through the vents.
I noticed that there is a plastic strip along the bottom edge of the window with a slot in it and that it appears that the scuttle panel should clip into this which would prevent water running down from the window however mine doesnt seem to clip in properly.
Anyone had this issue ?
