- Joined
- Dec 2, 2008
- Messages
- 17,400
- Reaction score
- 1,104
- Points
- 113
Some maps do, some don't but my IDCs are maxed out so the 4bar will fix that...if only just temporarily while I consider which 440cc's to go for. Saying that I've never heard of a fuel pump failing due to higher fuel pressure and it's rumoured that 3bar was only fitted to help the engine fall within EU emmission and fuelling regs. Either way, the old girl is screaming for more fuel that the 3bar just can't give.
Can you fit the MK2 LCR 4bar Fuel Pump to the MK1, Bill? As in a straight swap?
Hey guys, I think I have the same issue! Although during the last service I noticed that there was a small crack in the pipe going into the vacuum chamber next to the N249! I took the pipe off, cleaned it and taped it up. Since then it seems to have lost pressure, would you think the leak in the pipe caused this? I have an AMK engine (standard), should I remove the N249 and then see what it's like?
How much is the N75 valve and where does it live? Thank you in advance guys.
Read your story JamJay, sounds like you had a hell of a day the other day!!!!
the LCR pump is 4bar (mk1 1ML Leon)
