Hi....I can give you some firsthand experience on this!
We tried this on mine with the idea of keeping the underbonnet area looking stock,and gained a persistent high rpm misfire as a result.
The cause was tracked down to the stock system strangling airflow at peak rpm and causing the ECU to pull back,so the answer is yes,it will run,but it may well throw up a lot of misfire errors until you get a proper induction kit,and given the choice now,I would recommend the ITG.
I know you've mentioned dbilas there,but the ITG is quiet,very well made,and flows enough air for 500bhp.
