Pillar Pods
Welly
335D Driver :-)
37
Gloucestershire
Looking to get one for the S3 so I can pop a gauge in there - however I can't find one that is a direct fit. I bought a universal one and it was gash so I threw it away.
There are ones available for the Seat Leon, which I believe has the same dash.
Anyone know if it will just fit and go?
Do, different pillar if i rememeber mate.
I bought a universal one, cut and moulded it to the pillar, then fillerd it and sprayed it to match the centre console, only problem is i bought a textured pod so had to filler it all, going to re-do it with a smoothed faced pod so i dont have to use as much filler.
Tuffty made a decent job of fitting a universal one mate.
Yeah, and that's what I couldn't believe. It must of been a different on to the one I bought - it was about a million times too big to ever fit the pillar.
Nope, mine was, its called using a hack saw and heat gun haha.
im having a right nightmare fitting one of these its been a week since i started it lol. i used fibreglass. would a hot glue gun do the job of sticking it to the pillar?
My suggestion is to manufacturer your own using fibre glass and a 2nd hand a pillar off ebay so that you can return it to stock if required.
I did this once for tweeter pods on the wing mirror internal covers on a mondeo and it looked like the car came like that when I had finished. takes a while to do it though due to having to give a couple of coats of fibre glass and waiting for that + filler to heal so that you can sand them but the end result wont look bodged. :)
I fixed mine with countersunk screws and filled over the top
..before sanding and painting..
...finished article...
<tuffty/>
no one have tried column mounted ??
was thinking about it but thought they may just get in the way, im pretty sure a golf one would fit though.
why don't you buy one and we can see how it is and if it works, i might even get one then as my paint has bubbled so need to re-do it anyway
That being said...i will buy one.
I will get the work done to my car around september so will tell u by then.
it seems to be universal
he list the same item to mk4 too...
Nice to know it fits with a bit of trimming.
Lol i cant of cant wait to see if my column pod will fit
Looks interesting, and it is in your line of sight I guess.
How much does it interfere with your view of the other instruments?
Some pics of my pillar pod ;)
Just covered the pillar with a webbed tape so didn't damage the cloth and it also ment it could be pulled off to be cut and smooved out
The only downside was i cut a hole in the piller for the cables and pipe but besides that is very easy to remove as just clips over the pillar :)
it does interfere a little bit with the rpm red line, depending on your driving position.
I set the seats a bit high and i can see pretty much everything on the cluster...exept the lower part of the DIS.
Everyone that saw it was impressed, including myself. Its really not bad at all.
I didnt mention it in this thread but the pod that came from an MK4, needs a bit of trimming and cutting to get it fitted.
897
818
803
697
